Scaling model space dimensions to Viewport?
pedcarson
pedcarson
Is it possible to have dimensions and text in my model space, then in paper space have a viewport that scales the dimension or text to suit the viewport zoom ratio?
Either built in or through macro?
Replies (7)
pendean
Community Legend
Community Legend
You need to either use ANNOTATIVE text styles and dimstyles, or create a custom text style and custom dimstyle for every possible print scale you'd ever use.
Which are you using or wish to use?
pedcarson
I've made the dimensions annotative but when I go into paper space and click annotative scale sync at the bottom right, the viewport zooms to make the text fill the viewport instead of the viewport staying the same and the text getting bigger or smaller?
pendean
Community Legend
Community Legend
So it looks like you all do the old-school thing and create dimstyles for each predefined plotted scale. I suggest you start with an all new dimstyle instead of trying to just turn on annotative in a dimstyle set to a 1:5 plot scale.
Also ensure the text style being used in the annotative dimstyle set to be annotative as well: Tap that exclamation mark in the FIT tab and read all about it.
When you set the text style being used to annotative you also have to set the desired print text height as well: we use 3/32" for example.
pedcarson
I've been using a dimension style with annotative the last day and it seems like it could be good but have a few issues with it. Firstly the dimensions are tiny in the model space but scale correctly in paper in the images below. Secondly, if I go into paper space I have to go into a viewport and select a new scale then go back to the original one for the dimensions to scale properly. Is there a refresh setting for them? I tried regen but it doesn't do anything for them?
gotphish001
Not sure about why they don't regen, but I think I can help with the small text in model space. The scale at the bottom bar in model space is the annotation scale. That scale doesn't affect the drawing and you should always draw 1:1. What it does affect is what scale the annotative things show up at in model space. Change the scale to a scale that lets you see the text better. It won't affect anything in paperspace.
Also here is a link where David explains annotative stuff pretty good. It was another question I asked a while ago, but he explained it in an easy to understand way, I thought.
https://forums.autodesk.com/t5/autocad-architecture-forum/correct-set-up-to-dim-in-model-space/td-p/...
Nick DiPietro
Cad Manager/Monkey
place annotations in paperspace (where they belong)
pendean
Community Legend
Community Legend
CANNOSCALE has to be set in modelspace to match your papespace viewport scale: leaving it at 1:1 scale will always give you tiny text sizes since they are sized to a paper scale.
Try it.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
