AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Converting blocks from metric to imperial units
3 REPLIES 3
428 Views, 3 Replies
I have encountered an issue while trying to convert blocks created in metric system (mm) to imperial units.
I was looking for some answers in the knowledge data base and found some answers, but it didn't solve the problem.
Thing is, when for instance I am trying to use command "-dwgunits" that was recommended for this type issue, ale the blocks that have dynamic functions are afterwards either destroyed or scaled wrongly. Is there a way to overcome this?
Can anyone help?
Labels (1)
3 REPLIES 3
pendean
Leave blocks alone and explore using INSUNITS settings to control how AutoCAD imports content that are of different scale https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/AutoC...
Otherwise you should really recreate the blocks for a new "imperial" library from scratch.
in reply to: pendean
Thank you for your answer.
I was trying to do so, but didn't help much...I came across also this info: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-c...
Looks like dynamic blocks are not supported by INSUNITS... or am I getting it wrong?
pendean
Yes, that is correct too.
I guess you'll need to rely on manual scaling or creating a new imperial library of your custom dynamic blocks to use.
Technology Administrators
