I have encountered an issue while trying to convert blocks created in metric system (mm) to imperial units.
I was looking for some answers in the knowledge data base and found some answers, but it didn't solve the problem.
Thing is, when for instance I am trying to use command "-dwgunits" that was recommended for this type issue, ale the blocks that have dynamic functions are afterwards either destroyed or scaled wrongly. Is there a way to overcome this?
Can anyone help?
Thank you for your answer.
I was trying to do so, but didn't help much...I came across also this info: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-c...
Looks like dynamic blocks are not supported by INSUNITS... or am I getting it wrong?
