Show only
Search instead for
It would be nice to be able to edit dimension text like you can in Autocad. Not so much to change dimension but to add comments or symbols like "Overall" or "Typical" or .
Thanks for the reply. I have used this method but it is not ideal. This doesn't allow you to add text and keep the dimension associative. It also changes the content of every dimension in a row of connected dimensions. I think this could be greatly improved. I think it should be the same as editing text in Autocad.n Thanks.
