Edit Dimension Text
Edit Dimension Text
It would be nice to be able to edit dimension text like you can in Autocad. Not so much to change dimension but to add comments or symbols like "Overall" or "Typical" or Capture.JPG
2 Kommentare
haedicu
Status geändert in: Implemented
Please see the picture below:
This was implemented in Advance Steel 2016. Customers can also add object tokens / parameters and free text.
best regards
Udo
Nicht anwendbar
Thanks for the reply. I have used this method but it is not ideal. This doesn't allow you to add text and keep the dimension associative. It also changes the content of every dimension in a row of connected dimensions. I think this could be greatly improved. I think it should be the same as editing text in Autocad.n Thanks.
Idee einsenden
