Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
assembly part
4 REPLIES 4
GHASEM_ARIYANI
286 Views, 4 Replies
assembly part
How can we build assembly part?
For example I want the picture below An assembly created.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
4 REPLIES 4
I think I read on another thread to try AutoCAD 'group' and then advance copy.
Bogdan.O
in reply to: GHASEM_ARIYANI
You must weld the base plate and the stiffeners to the T shape column if you modeled the plates manually.
As an alternative, you can apply the Base plate connection (with values for Base plate and Anchors) and Stiffener connection (with values for Chamfer and Pattern). The connections will include welds.
Did this solve your question?
Bogdan.
Bogdan Orzea
QA Analyst
I mean, this is This collection is I want an assembly.
How can I find out The collection is an assembly Drawing.
As teklastructures in the Space Drawing Project is a collection assembly can recognize. See. Select. Edit....
GHASEM_ARIYANI
in reply to: Bogdan.O
I was drawn to intentionally separately.
So I set out to create an assembly
Technology Administrators
