How can we build assembly part?
For example I want the picture below An assembly created.
I think I read on another thread to try AutoCAD 'group' and then advance copy.
You must weld the base plate and the stiffeners to the T shape column if you modeled the plates manually.
As an alternative, you can apply the Base plate connection (with values for Base plate and Anchors) and Stiffener connection (with values for Chamfer and Pattern). The connections will include welds.
Did this solve your question?
Bogdan.
I mean, this is This collection is I want an assembly.
How can I find out The collection is an assembly Drawing.
As teklastructures in the Space Drawing Project is a collection assembly can recognize. See. Select. Edit....
I was drawn to intentionally separately.
So I set out to create an assembly
