Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Bolts to a Group
7 REPLIES 7
Message 1 of 8
GHASEM_ARIYANI
946 Views, 7 Replies
Bolts to a Group
hi
i used Split Bolt group and But I want them to be converted back to a group .Is there a solution?
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
7 REPLIES 7
Message 2 of 8
There isn't a way to turn a split group back into a pattern. From the picture, that bolt configuration isn't a "Pattern" but a number of possible patterns.
You maybe can redraw the bolts as smaller patterns?
Message 3 of 8
hi
This means that if I want to edit it, I should be the one to do one?
Message 4 of 8
Yes. You need to move each bolt individually.
Message 5 of 8
It's too bad.
But I think this group of AutoCAD tools to help us.
Message 6 of 8
I believe that those tools are for the BOM on drawings. But someone else will have to verify that. I have not used those for grouping AS pieces before. I am curious to see if it works though. Let us know.
Message 7 of 8
Grouping bolts using Group command, only makes them selectable together.
You cannot return to the Advance Steel functionality (for example to edit distance between bolts).
I recommend using smaller bolt groups.
Bogdan Orzea
QA Analyst
Message 8 of 8
GHASEM_ARIYANI
in reply to: Bogdan.O
Thanks for your response
