Hi, I was trying to get a welding connection between a tube profile and a circular plate. I figured out to use the "weld point" so as to get an assembly between the pieces, but I was wondering if is there another way to do it in order to get the all around welding.
Sorry if is something basic but I am a neewbie with AS. Thanks in advance.
Somebody correct me if I'm wrong, but I'm afraid you need to do it by hand, by going around and on each pair of points...
EDIT: Assuming you already made all the correct cuts, that is.
In order for Advance Steel to display an all around weld, you need to check the "Continuous" box. That will place the all around circle on your weld symbol.
