Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
How to do a circular weld?
4 REPLIES 4
antonio.delacruz
826 Views, 4 Replies
Hi, I was trying to get a welding connection between a tube profile and a circular plate. I figured out to use the "weld point" so as to get an assembly between the pieces, but I was wondering if is there another way to do it in order to get the all around welding.
Sorry if is something basic but I am a neewbie with AS. Thanks in advance.
Spoiler
4 REPLIES 4
in reply to: antonio.delacruz
Somebody correct me if I'm wrong, but I'm afraid you need to do it by hand, by going around and on each pair of points...
EDIT: Assuming you already made all the correct cuts, that is.
antonio.delacruz
Thanks for your response, it seems this is the only way to get it. Only comment I couldn't find "all around" type in the main weld types, so I left "fillet weld" as welding type.
In order for Advance Steel to display an all around weld, you need to check the "Continuous" box.  That will place the all around circle on your weld symbol.
antonio.delacruz
Thanks again Paul for helping me out.
