hi
i used Split Bolt group and But I want them to be converted back to a group .Is there a solution?
hi
This means that if I want to edit it, I should be the one to do one?
It's too bad.
But I think this group of AutoCAD tools to help us.
Grouping bolts using Group command, only makes them selectable together.
You cannot return to the Advance Steel functionality (for example to edit distance between bolts).
I recommend using smaller bolt groups.
Thanks for your response
