Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Advance Steel custom commands-share your ideas
814 REPLIES 814
Message 1 of 815
acbsdesign
93914 Views, 814 Replies
acbsdesign
It will be nice to learn more about custom commands / combination of Autocad and Advance Steel commands improving productivity.
To colleagues willing to share-Thank you.
Here is a tiny example:
"Hide parts with identical numbers"-used when parts are detailed using drawings styles.
^C^C_AstM5equalpartsMarkSame \;AstM4CommSelectMarkedObjects ;_AstM4SwitchReprMode off
And another one:
"Hide Similar Advance Steel Objects":
^C^C_SelectSimilar \;_AstM4SwitchReprMode off
Ilko Dimitrov
ACBS
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
And another one:
Ilko Dimitrov
ACBS
814 REPLIES 814
Message 681 of 815
Sebastian_Eiche
Should be this command:
_AstM4CommModelSelection;HAVEDETAILS;1;1;0;_AstM4CommSelectMarkedObjects;_AstM4SwitchReprMode;off;
The part with "HAVEDETAILS" had to be replaced with the name of the querry which you save.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
Message 682 of 815
Matrix-Software
Thanks Sebastian,
I changed it to _AstM4CommModelSelection; HAVEDETAILS;1;1;0;_AstM4CommSelectMarkedObjects;_AstM10ViewSelObjects HIDEASSEMBLY;
And it works as it should be.
Thanks Sebastian,
Message 683 of 815
Sebastian_Eiche
What we forgot: maybe an "unmark" would be good. because if we use the hide commands, the marking will be there, this could be a problem for the next commands.
So I would add: _AstM4CommUnmarkObjects
Sebastian Eiche
Sebastian Eiche
Message 684 of 815
acbsdesign
in reply to: acbsdesign
acbsdesign
Hi, To summarize the 3 latest posts:
Isolate Assemblies to be detailed (or hide detailed assemblies):
ASSEMBLIESTOBEDETAILED entered as a name in queries:
_AstM4CommModelSelection;ASSEMBLIESTOBEDETAILED;1;1;0;_AstM4CommSelectMarkedObjects;_AstM10ViewSelObjects HIDEASSEMBLY;_AstM4CommUnmarkObjects;graphscr;redraw;
Thank you @Sebastian_Eiche  and @Matrix-Software
Message 685 of 815
bigcarl5000kg
bigcarl5000kg
great stuff 🤘
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
great stuff 🤘
Message 686 of 815
acbsdesign
acbsdesign
@bigcarl5000kg  Nothing can beat the power of users when working together.
Message 687 of 815
bigcarl5000kg
bigcarl5000kg
one-for-all, all-for-one
Message 688 of 815
Yogesh.Indalkar
@acbsdesign @Sebastian_Eiche
Hello experts,
When I save this custom command in my CUI.
I found that whenever I press control +S ( save ) my cad drawing gets close.
Is there any way to use this command for detail drawings only not for CAD model file. ?
Hello experts,
Message 689 of 815
Yogesh.Indalkar
Hello all AS  experts here,
I have created few custom commands in my Ribbon & tool pallet.
Now I want to add those commands into my right mouse button shortcut.
Is there any way to do so??
Message 690 of 815
Matrix-Software
You van do it for instance here:
Message 691 of 815
Yogesh.Indalkar
@Matrix-Software Thank you for your prompt reply.
I have attached one snap in which one cad model is open & 8 panel drawings are open.
Whenever I close any detail drawing then it ask me YES or No to save it.
I want to save it by default whenever I close any drawing without any popup.
Thanks in advance.
Thanks in advance.
Message 692 of 815
Yogesh.Indalkar
Now I want to replicate them in my other Team-mates Computer systems.
Is there any quick way to do so??
Refer attached snap.
Message 693 of 815
acbsdesign
acbsdesign
Something that may help users who have the same problem as I do: when shear plates and stiffeners have the same geometry on both sides of a beam, only the N/S gets labeled.
So I did change their representation in Beam Front View for N/S to be Visible only, and left the F/S to be visible Hidden
Labeling Strategy for F/S-I use the old method:
This is for N/S (per Area):
And the result is:
Happy Friday.
And the result is:
Happy Friday.
Message 694 of 815
livewirefabrication
Observer
Observer
Hello all,
I was watching a video on youtube by EIRCAD (Adrian Mangan) and he referenced a compiled list of the custom commands the brilliant minds here have amassed amidst all of these posts. Can anyone please drop a link to this compiled list so I can start customizing my workspace and maximizing my output?
Eric S-K
Hello all,
Eric S-K
Message 695 of 815
Jonathan3891
Look through this thread and you'll find them.
Jonathan Norton
Blog | Linkedin
Jonathan Norton
Blog | Linkedin
Message 696 of 815
acbsdesign
acbsdesign
@livewirefabrication
The above-referenced person is all "copy and paste" piece of work.
He should not be allowed to do that, but it is what it is.
The world sucks anyway, another $ucker does not make a huge difference.
There are a few posts with summarized commands, but best if you go through all.
Have a great day.
Have a great day.
Message 697 of 815
livewirefabrication
Observer
Observer
Ok! thank you!
Ok! thank you!
Message 698 of 815
bigcarl5000kg
bigcarl5000kg
Hi everyone,
one LISP for opening a group before editing / closing a group after editing, if someone uses standard AutoCAD groups in Advance Steel, or for editing such groups in eg. more complex Advance Steel object templates (drawing BOMs, etc.).
Command: GG (or individual after change of the LISP content)
It changes the value of PICKSTYLE between 1 and 0 and allows editing of individual objects in the group.
Have a nice weekend
Hi everyone,
Have a nice weekend
Message 699 of 815
dave_conibear
All.........good afternoon
I am trying to create a custom command that will essentially select and show only AS objects (ie no construction lines etc etc)......It's a combination of select all AS objects
show only selected items
This is my command line that doesn't work
Could someone help with a correction please
thanks
thanks
Message 700 of 815
markhubrich
markhubrich
Does anyone happen to have a custom command to select all bolts and make them solid representation? Same for anchors. Quite often bolts and anchors will go into "stick figure" for no apparent reason.
...and fix the kiss export issues.
