It will be nice to learn more about custom commands / combination of Autocad and Advance Steel commands improving productivity.
To colleagues willing to share-Thank you.
Here is a tiny example:
"Hide parts with identical numbers"-used when parts are detailed using drawings styles.
^C^C_AstM5equalpartsMarkSame \;AstM4CommSelectMarkedObjects ;_AstM4SwitchReprMode off
And another one:
"Hide Similar Advance Steel Objects":
^C^C_SelectSimilar \;_AstM4SwitchReprMode off
Ilko Dimitrov
ACBS
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
Solved by Jonathan3891. Go to Solution.
Solved by Sebastian_Eiche. Go to Solution.
Solved by acbsdesign. Go to Solution.
Solved by mick-CNF. Go to Solution.
Solved by vuk.vukanic. Go to Solution.
Solved by bigcarl5000kg. Go to Solution.
Solved by MetallPlanMerkinger. Go to Solution.
Solved by Matrix-Software. Go to Solution.
Solved by Ryan-J. Go to Solution.
Solved by Julio_Soto. Go to Solution.
Should be this command:
_AstM4CommModelSelection;HAVEDETAILS;1;1;0;_AstM4CommSelectMarkedObjects;_AstM4SwitchReprMode;off;
The part with "HAVEDETAILS" had to be replaced with the name of the querry which you save.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
What we forgot: maybe an "unmark" would be good. because if we use the hide commands, the marking will be there, this could be a problem for the next commands.
So I would add: _AstM4CommUnmarkObjects
Sebastian Eiche
Hi, To summarize the 3 latest posts:
Isolate Assemblies to be detailed (or hide detailed assemblies):
ASSEMBLIESTOBEDETAILED entered as a name in queries:
_AstM4CommModelSelection;ASSEMBLIESTOBEDETAILED;1;1;0;_AstM4CommSelectMarkedObjects;_AstM10ViewSelObjects HIDEASSEMBLY;_AstM4CommUnmarkObjects;graphscr;redraw;
Thank you @Sebastian_Eiche and @Matrix-Software
great stuff 🤘
@bigcarl5000kg Nothing can beat the power of users when working together.
one-for-all, all-for-one
Hello experts,
When I save this custom command in my CUI.
I found that whenever I press control +S ( save ) my cad drawing gets close.
Is there any way to use this command for detail drawings only not for CAD model file. ?
Hello all AS experts here,
I have created few custom commands in my Ribbon & tool pallet.
Now I want to add those commands into my right mouse button shortcut.
Is there any way to do so??
@Matrix-Software Thank you for your prompt reply.
I have attached one snap in which one cad model is open & 8 panel drawings are open.
Whenever I close any detail drawing then it ask me YES or No to save it.
I want to save it by default whenever I close any drawing without any popup.
Thanks in advance.
Now I want to replicate them in my other Team-mates Computer systems.
Is there any quick way to do so??
Refer attached snap.
Something that may help users who have the same problem as I do: when shear plates and stiffeners have the same geometry on both sides of a beam, only the N/S gets labeled.
So I did change their representation in Beam Front View for N/S to be Visible only, and left the F/S to be visible Hidden
Labeling Strategy for F/S-I use the old method:
This is for N/S (per Area):
And the result is:
Happy Friday.
Hello all,
I was watching a video on youtube by EIRCAD (Adrian Mangan) and he referenced a compiled list of the custom commands the brilliant minds here have amassed amidst all of these posts. Can anyone please drop a link to this compiled list so I can start customizing my workspace and maximizing my output?
Eric S-K
The above-referenced person is all "copy and paste" piece of work.
He should not be allowed to do that, but it is what it is.
The world sucks anyway, another $ucker does not make a huge difference.
There are a few posts with summarized commands, but best if you go through all.
Have a great day.
Hi everyone,
one LISP for opening a group before editing / closing a group after editing, if someone uses standard AutoCAD groups in Advance Steel, or for editing such groups in eg. more complex Advance Steel object templates (drawing BOMs, etc.).
Command: GG (or individual after change of the LISP content)
It changes the value of PICKSTYLE between 1 and 0 and allows editing of individual objects in the group.
Have a nice weekend
All.........good afternoon
I am trying to create a custom command that will essentially select and show only AS objects (ie no construction lines etc etc)......It's a combination of select all AS objects
show only selected items
This is my command line that doesn't work
Could someone help with a correction please
thanks
Does anyone happen to have a custom command to select all bolts and make them solid representation? Same for anchors. Quite often bolts and anchors will go into "stick figure" for no apparent reason.
