Advance Steel custom commands-share your ideas
acbsdesign
Mentor Mentor
Message 1 of 815
acbsdesign
It will be nice to learn more about custom commands / combination of Autocad and Advance Steel commands improving productivity.
To colleagues willing to share-Thank you.
Here is a tiny example:
"Hide parts with identical numbers"-used when parts are detailed using drawings styles.
^C^C_AstM5equalpartsMarkSame \;AstM4CommSelectMarkedObjects ;_AstM4SwitchReprMode off
And another one:
"Hide Similar Advance Steel Objects":
^C^C_SelectSimilar \;_AstM4SwitchReprMode off
Ilko Dimitrov
ACBS
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Accepted solutions (126)
Replies (814)
Message 601 of 815
acbsdesign
@bigcarl5000kg
Many thanks for the input.
Not sure if I read the lines correctly, mine cut hatches are working fine. Visible hatches do not allow different scales, only different colors.
Have a great rest of the weekend.
Message 602 of 815
acbsdesign
@bigcarl5000kg
I think you are correct, I did enter the values in AstCurrent DetHatch… only.
Will test on Monday, but probably this is it.
 Thank you again.
Message 603 of 815
acbsdesign
Hi @bigcarl5000kg
No, it is not working, scale stays same as in the model.
Message 604 of 815
bigcarl5000kg
hmmm, weird, did you change the drawing style settings too?
I tested it on a camera cut, here it really works.
But with the manual cut in drawing, yeah it doesn't work right - minimal not for the hatch angle. Here became the 0° value another representation as in camera cut = 45° rotated (=false)! Why? That's magic 😃 ...
bigcarl5000kg_0-1647258833227.png...
After editing (Winkel = angle):
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Message 605 of 815
acbsdesign
@bigcarl5000kg
The hatch that is shown on the screenshots is Cut, not Visible.
Yes, I have applied all representation types properly, in AstorDetails----Hatch and ObjectAppearance and in CurrentAddin----Hatch and ObjectApperance.
There is either a bug or it was left undeveloped.
Thank you for your time,
Hopefully, someone from the big size company called AD would look at this small thing.
Or maybe it is so small, they would not even look at it.+
Whatever another 20 years I will retire.
Not having the scale for Visible Hatches fixed.
If the world exists in 20 years.
This seems to be not very likely.
Message 606 of 815
bigcarl5000kg
SOMETIMES!! And it's happening by accident!!
Hatch via Camera cut:
0° value = 45° representation of hatch in drawing
90° value = 135° representation of hatch in drawing
Hatch via manual cut:
0° value = 0° representation of hatch in drawing
90° value = 90° representation of hatch in drawing
WHY??? ....
Examples with the same settings for hatch, but with another representation (hatch angle):
Message 607 of 815
acbsdesign
@bigcarl5000kg
Actually - there is a way for the world to survive for more than 20 years-a meteor hitting the Earth, partially killing the bad and saving the good.
And the good buying BOXABL by Tesla.
I will put mine near the lake. Upstate NY.
Or in the Chesapeake / Virginia Beach area.
Message 608 of 815
acbsdesign
But then the question would be-how does the meteor know who is good and who is bad.
We have to call the aliens to give them directions.
Will use Google Translator.
Message 609 of 815
bigcarl5000kg
Hmm ... if the Reseller is on the Earth and Advance Steel on the Halley comet, then the "expected" version of Advance Steel will reach us approx. once every 75.3 years ... without any help from extraterrestrial civilization 😎
"K"
Message 610 of 815
bigcarl5000kg
Here some small (help) tools - predefined construction lines (Xline = endless line) - similar to AutoCAD Mechanical. Icons see attachment.
Horizontal Xlines (automatic multiple)
^C^C^C_.xline;_hor
Vertical Xlines (automatic multiple)
^C^C^C_.xline;_ver;
Perpendicular Xlines to line (multiple)
*^C^C^C_.xline;_ang _ref \90 \;
Offset Xlines to linear object (automatic multiple)
^C^C^C_.xline;_offset;
Angle bisecting Xlines (multiple)
*^C^C^C_.xline;_bisect \\\;
Xlines tangent to two circles (multiple)
*^C^C^C_.xline;_tan;\_tan;\;
ESC key interrupt the multiple Xline commands
bonus - crossing Xlines 90° (multiple)
*^C^C^C_.xline;\@100,0 @100<270;;
Message 611 of 815
acbsdesign
@bigcarl5000kg
Awesome,
Thank you for sharing.
Have a great rest of the day.
Message 612 of 815
acbsdesign
Hi everyone,
Looking for a way to explode joints by selecting an element of a joint, if the joint box is not visible,
without using Advance Joint Properties+select+explode.
Thank you.
Message 613 of 815
Sebastian_Eiche
Have a look in the ribbon where the connection vaul is located in the extended modeling tab. There's a command (not sure how it is called). But with this command you could select an object and after this, the joint box of this element will be selected. Then it's just the 'delete' command which had to be added
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 614 of 815
johnjmbennett
Extended modelling >joint utilities > display
John Bennett
Message 615 of 815
acbsdesign
@Sebastian_Eiche @johnjmbennett
Thank you very much. How come never used this one...
Message 616 of 815
acbsdesign
"Update page header" comes usually after some modifications are done in Project Settings, which always requires "Update defaults".
Example-drawn on or checked on date-we have to update defaults all the time prior to updating page headers.
Adding the "Update Defaults" command in front of "Update page header" eliminates the going back and updating defaults if we forget to run update defaults first.
Update Defaults and Update Page Header-modified existing Update Page Header command:
^C^C_AstM4ReopenDatabase;AstM4CommDetUpdateProjectData
Hope some will find this helpful, I did.
Message 617 of 815
acbsdesign
Probably it is worth sharing, XCLIP - very often overlooked, but so useful.
Below is a short screencast of trimming roof-joist and deck-block (steel by others)
XCLIP
Message 618 of 815
Sebastian_Eiche
Did someone already call the command ncopy? Very useful to copy elements from a xref without opening the xref
Sebastian Eiche
Message 619 of 815
acbsdesign
@Sebastian_Eiche
Have you ever had an issue with xrefs and Shared Views?
The entire model gets dark in Shared Views.
Will try ncopy.
Message 620 of 815
edumatfind2021
Community Visitor
Community Visitor
Advance Steel is a CAD software application for 3D modeling and detailing of steel structures and automatic creation of fabrication drawings, bill of materials and NC files. It was initially developed by GRAITEC, but was acquired by Autodesk in 2013. The software runs on AutoCAD.
Education Matters is a leading professional top overseas education consultant in Chennai and Hyderabad. We help students in gaining a better quality of education overseas with the help of professional consultants.
