3ds max 2017 viewport freezing and stopped working
Message 1 of 216
Hello, i got some issues with my 3ds max. it always freezing when i click it and then the viewport turns black.
and sometimes it just showing and error and saved my file into backup folder.
i have i7-6700, GTX 970 and 16gb ram with windows 10 running.
please help.
Replies (215)
Message 181 of 216
If this is only a Nvidia driver problem, why Max 2016 is working without problems in that area? That suggest that there is something from the Max side that could be changed to make it OK.
Message 182 of 216
... What about 2018? still the same? or is it fixed there? I can't tryit
because I have Maya + Max license type... and I guess until there is not
Maya 2018 I won't be able to download Max 2018... ( if that makes any sense
to anyone ).
Come on Autodesk, several months with this quite BIG problem.
Message 183 of 216
to anyone ).
Message 184 of 216
Alfred.DeFlaminis
Hello @Anonymous,
Max 2016 wasn't created for Windows 10, which has updated requirements for driver development.  Take a look at this thread, it's W10 people that are most affected.   Also, 2017 and later were coded to take more advantage of the GPU which puts even more stress on the drivers and OS.
@Anonymous,
It affects 2017 and 2018 until it is addressed.
Best Regards,
Message 185 of 216
Yes, the issue persists in Max 2018 as well. This thread was created in August of 2016. It is now almost a year later and we have a new version of max with the same problem yet to be fixed. Is there any indication as to when we can expect this problem to be resolved? I too have to default to Max 2016 as the most confident stable version for my day to day billable work. My maintenance is up for renewal in sept, and I hate that basically the only reason I am still interested in renewing is because I need to retain previous version rights so I can still use a version of max that works. I would like to be happy about renewing max so I can continue to utilize a great program with new innovative features, etc, but that just isn't the case if the software is unusable. I basically feel trapped because I have to renew to be able to use 2016, but I don't want to renew unless I can be confident that I am getting more than the ability to use old software. Please expedite this fix because I know all of us are very anxious to use Max daily and be confident it will function as advertised.
Message 186 of 216
Alfred.DeFlaminis
Hello @Anonymous,
It's a driver issue to be fixed by NVIDIA.  All you should have to to do in the meanwhile is switch to DX9.  I understand your POV and I respect it, but I have done all I can do until this issue is resolved via drivers.
Best Regards,
Message 187 of 216
Anyway these are changes done from Autodesk side to take advantage of windows 10 and Nvidia and are not working. If they are not working it would be logical to step back to how was done in Max 2016 that is perfectly compatible with Windows 10 driver support and the Nvidia drivers.
There is no point to do changes in Max to take more advantage of the GPU if it is necessary to use DirectX 9 that is slower and with less features. It is just the opposite to an upgrade.
And depending of Nvidia to fix this could mean another year or never before this is fixed. You simply has not control of what Nvidia can do and a year has already pass. They seem to have very little interest to fix it.
I really like Max and this simply try to point a constructive critic. It is a bit odd to have a roadblock like this with no end visible.
Message 188 of 216
one year, and still no fix? i would like to move to 3dsmax2017 or even 3dsmax2018. i but i cannot, just because of this viewport crash/freeze.
this is very poor from autodesk side. sorry to say that, i am deep disappointed
best regards
peter
(max user since over 20 years)
Message 189 of 216
Alfred.DeFlaminis
Hello @all,
The updated drivers are released now at NVIDIA.com.
GeForce driver 384.76  is available for GeForce users.
Quadro drivers are specific to the model number, see NVIDIA.com for details and the update.   The release date for fixed drivers is roughly the 16th of June or later versions.
These drivers fix the viewport freezing issue and this fix should be included in all versions moving forward.  Our very own @gregg_lagnese has performed extensive testing and we've gotten confirmation from the community so I am confident that I can finally mark this issue as Solved.  Thank you all.
Best Regards,
Message 190 of 216
Those drivers were released 18 days ago. Problem remains.
Message 191 of 216
lightcube
Is it verified to fix the viewport freezing issue in 2017+?
Shawn Olson
Developer of Wall Worm
3ds Max plugins and Scripts
3ds Max 4/Gmax - 3ds Max 2020
Mudbox 2009-2019
Windows 10 x64
i7 8700K
64GB RAM
Geforce 1080ti
Message 192 of 216
Marc_Auv
I can confirm the problem persist with those drivers in max 2017 and Max 2018 for my part.
Windows 10 creators update x64
GTX 1060 drivers 382.53
Intel I7 6900k
32GB RAM
AUVIGNE Marc
3D Artist / Freelance
Facebook | LinkedIn
Message 193 of 216
mmurzyn
Alfred,
Sorry, I’m seeing the same issues with this driver and with the new 3DS updates from the .max file I sent you and the file you sent me.
Using a new clean DELL Z440 w/ NVIDIA Quadro M500
Mike Murzyn
Technical Product & Marketing Manager
ClarkDietrich Building Systems
9100 Centre Pointe Dr. Suite 210
West Chester, OH 45069
p. 513-870-1109 m. 513-435-3417
[cid:image001.png@01D2EF49.D8586B10]
www.itools.clarkdietrich.com
A full spectrum of solutions….
Message 194 of 216
Alfred.DeFlaminis
Hello all,
Ok thank you for the update.  The version we tested internally was a beta version and it passed the tests, but maybe when it was rolled into the main drivers something happened.  I'm ringing bells now.  In the meanwhile you might want to be sure you remove all traces of old drivers before installing.
Best Regards,
Message 195 of 216
New drivers were released today. So far so good.
Message 196 of 216
alexnode
Please let us know ... ! That sounds good , Nvidia told me they were on the
case as i filed a support ticket. But i couldn't give them crash logs and
stuff because i uninstalled 2017 four months ago .
#- Please type your reply above this line -##
Message 197 of 216
Problem is resolved, at least in my case.
Message 198 of 216
mmurzyn
So far, all test files that I had issues with before are working fine on my HP Z440 w/ NVIDIA QUADRO M5000
Thanks for posting!
Mike
Message 199 of 216
Alfred.DeFlaminis
Oh that is such good news.  Thank you for the confirmation.  I think there was a minor communication issue about which release the fix was in and I'll own that one.  Thanks all for the update and confirmation.
Best Regards,
Message 200 of 216
darawork
M5000, as in Maxwell?
I wonder if that means the Pascal P5000 works too?
This could be good news?
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
