3ds max 2017 viewport freezing and stopped working
Message 1 of 216
Hello, i got some issues with my 3ds max. it always freezing when i click it and then the viewport turns black.
and sometimes it just showing and error and saved my file into backup folder.
i have i7-6700, GTX 970 and 16gb ram with windows 10 running.
please help.
Replies (215)
Message 161 of 216
I agree. Issue is, I took a lot of time to uninstall and reinstall plugins for example Vizpark plug ins, itoo software etc. I should not have to go through this charade. If I stay with max, I may just have to accept that I need to reinstall 2016. However, I do not think it should take 6 months to issue a fix for this relatively small issue it would seem.
Message 162 of 216
gregg_lagnese
@Anonymous wrote:
My problem now is that I have had a Maintenance Subscription on my home version as well as both of my work versions for practically as long as subscriptions have been offered, and I am now faced with the prospect of having to move to the new subscription plan for all 3 systems. My director at work is very concerned about moving to a new subscription that will be more expensive, and we can only rely on a 2 year old version of the software to use in production. I share the same concerns for moving to the new subscription service for my home license as well. I have used 3ds Max since the old DOS versions, and I have loved using it, but I am thinking now that this might be the end of the road. It is hard to justify the increased expense at this point for a 2 year old version of the software. I will have to do a lot of thinking about this.
With subscription (vs maintenance) you will not need 'Home use' at all.  With subscription you can use the current version, or up to three versions back on any of your systems.  Your logon will be all you need to run the software from each new system.
Message 163 of 216
gregg_lagnese
It's a driver issue so the service pack can't fix it.  We need updated drivers from NVidia.
@Anonymous wrote:
Service Pack 1 was released. Problem still appears. This is unacceptable. This time I am moving away from Max.
Message 164 of 216
darawork
It is coming. Give AJ a chance.
It's been announced. Proper nVidia drivers.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
Message 165 of 216
darawork
Notepad ++ instalation got corrupted, I personally blame Filehippo.
Darawork
AutoDesk User
Message 166 of 216
Alfred.DeFlaminis
Hello @Anonymous,
This thread is about a freezing viewport, not hard crashes.  If you are having crashing issues please start a new thread and I will help you.  I have checked the CER logs and I have 0 submitted from you.  If you crash and want help with it, submit a CER with your email address and I can help you.
@Anonymous
The freezing issue will be fixed by a driver from NVIDIA, not a service pack.
Best Regards,
Message 167 of 216
darawork
@Anonymous, I've an office with four 12gb P5000s Quattro card installations. We're all on 16 until this is "Old news"
Darawork
AutoDesk User
Message 168 of 216
ivanisavich
Since you guys are apparently in talks with nVidia about this issue, have they provided an ETA for when it will be resolved?
Message 169 of 216
darawork
Paperwork. Stocks and shares.
Darawork
AutoDesk User
Message 170 of 216
darawork
July.
Darawork
AutoDesk User
Message 171 of 216
Freezing viewport is what I have been experiencing for months.
Message 172 of 216
darawork
Same here. I've personally punched through 5x Dell 28" monitors.
Darawork
AutoDesk User
Message 173 of 216
darawork
As said, above 2016 with vRay 3.4 is as good as any Aspirin.
Darawork
AutoDesk User
Message 174 of 216
Alfred.DeFlaminis
Hello @Anonymous,
Using DX9 fixes the frozen viewport for the vast majority of people, but apparently not all.  What are your current plugins?
Best Regards,
Message 175 of 216
Hi Gregg,
Thanks for your info regarding home use on Subscription vs. Maintenance. I use my "Home" version for freelance work not associated with Work work so I pay for a home license to not get in trouble for using work software for personal use.
My main issue is not that I have to pay for 3 licenses between my work versions and my home version. It is that I have to use a 2 year old version of the software for production. I can not "trust" the newer versions yet to rely on them in a production environment. It is rapidly coming up time to renew all 3 versions, either for Maintenance or Subscription, and I am having a hard time justifying the expense to my bosses when I am using a 2 year old version of the software. They are asking me why they are paying this yearly expense if I am using an older version. My response that the newer versions are not stable in a production setting yet is not flying well with them, so you can see my dilemma about renewing. Working for a state institution, budgets are tight and they want results from the money they spend and I don't have an answer for them. See my dilemma?
Message 176 of 216
gregg_lagnese
newmans -
You can E-mail me because subscription and mainteance isn't really part of this thread.  Home Use is not for separate production purposes unrelated to the license holder's LSA.  Read the first paragraph in the FAQ (link below).
Home Use FAQ
If you mean Home version as in "my own license," that is different.  Maintenance gives you access to direct support, add-on items, training, and access to the current versions plus three back.  Therefore, today you get support on Max 2015-2018.  If you don't care about any of that, and want to rely on forum type help, you don't need to pay for maintenance.  However, at that point, you have to stick with the last supported version when you terminate maintenance (you can't use all of the four versions, just one).  If you were stuck on 2014 for example, it might make sense to drop maintenance.
One big caveat:  If you drop maintenance, you will lose your license's perpetual status.  You cannot restart maintenance and get the a later version.  You will have to buy a new subscription.  However, you can buy subscriptions in shorter chunks (i.e., monthly), so that might actually work better for you.
All software has issues, and this particular threads issue is related to a video driver defect we uncovered.  I, like you, am at the mercy of the drivers of the hardware sometimes.  My ATI card, for example, does not have this problem.
Message 177 of 216
I am currently using the Vizpark plugins. Vray 3.4 or 5.
Message 178 of 216
Alfred.DeFlaminis
Hello @Anonymous,
There is a problem with W10 and the Vizpark Walls and Tiles with Max 2017 and NVIDIA drivers right now.  It's fine on Win7 or with ATI from what I've seen, but I believe the root of the issue is the driver issue being discussed in this thread.  I've emailed with Martin, the CEO of Vizpark about this quite a bit.  He's a nice guy who really wants to see a resolution for his customers.  On my machine (Win7, Quadro K2100M) I have not been able to crash it at all and I've tried.
EDIT: Spelling
Best Regards,
Message 179 of 216
Hi Alfred,
Martin is indeed a great guy and has always come back to me when I have emailed regarding issues or if I have needed help with plug ins.
I look forward to the fix. In the meantime, please keep us updated on progress where you can on this thread and if and when you can release a date for the expected fix.
Many thanks,
Carl
Message 180 of 216
Alfred.DeFlaminis
Hello @Anonymous,
I very much look forward to when this fix is pushed out.  It's really important to all of us and I promise to post in here the second I find it's released.
Best Regards,
