Simple Lisp for Cross lines between rectangle.
zaid.k3112
Message 1 of 24
zaid.k3112
Hello, I need a simple lisp which lets me select a 2 points i.e. a rectangle in which it will make cross lines in a desired layer with line type.
Replies (23)
Message 2 of 24
ВeekeeCZ
Ok, and what exactly do you need to help with? You did not post any code so... nothing to help with.
Message 3 of 24
zaid.k3112
I was wondering if such lisp exists. Its very simple. But i cannot find in the forums
Message 4 of 24
ВeekeeCZ
Well... dunno. Frankly, from your explanation I'm not sure what you want... better post some dwg ....
Message 5 of 24
Sea-Haven
You mean a X on a rectang just get co-ordinates of the rectang, draw line pt1 pt3 and pt2 pt4.
Message 6 of 24
-didier-
Bonjour @zaid.k3112
First I would like to know if you want to learn AutoLisp,
or if you want someone to write you a program to do this work.
If you are learning, give us the code already written, and we will correct it to make it work properly.
If you want a program from scratch, thank you for giving a specific example of what needs to be done, and from which it needs to be done.
It’s a matter of respect for people who want to help others.
Either way, we should find a solution.
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Message 7 of 24
Kent1Cooper
If "a rectangle" means a closed Polyline such as is made by the RECTANG command, then you don't need to select 2 points, but a routine would be able to find the points from just a single pick of the Polyline [see Message 5].  And that could work whether the rectangle is orthogonally oriented or at any angle, or just a quadrilateral [not necessarily rectangular].
If "a rectangle" might be something else [e.g. 4 Lines, perhaps not even ending at the corners but, for example, in a space within a grid of Lines or Xlines, etc.], and if they would always be orthogonal, that would also not be difficult if you are sure to select two diagonally opposite corners [a Line between the 2 points, and one from X-of-one-and-Y-of-the-other to Y-of-one-and-X-of-the-other].  But that won't work if the rectangle or grid is not orthogonally oriented.
So what's the expected situation?
There are routines out there, such as >this< that includes the drawing of the rectangle as a Polyline, and others on the same Topic that use Lines, from which you can take the diagonal-Line-drawing parts only.
Kent Cooper, AIA
Message 8 of 24
Sea-Haven
Waiting for OP the other option is want X or +
Message 9 of 24
zaid.k3112
I have attached drawing. Suppose you have a rectangle (named as 1 in drawing). And I want the desired cross lines as shown in the 2nd rectangle (named as 2 in drawing), I will have to manually do it. I need to find a lisp where I click 2 points as mentioned in the drawing so that the desired result is achieved
Message 10 of 24
zaid.k3112
Hey, the lisp you mentioned is what i need to do. But i dont need the rectangle itself, just the lines inside. Apart from that, I need it in a specific layer, linetype scale, line type etc. This is secondary. I am a noob in lisp. Can i tell me which line to remove in the mentioned lisp so that it does what i need to do?
Message 11 of 24
zaid.k3112
Hello, I was wondering if such lisp exists, as it is very simple one.
Message 12 of 24
ВeekeeCZ
Try this. Fix *.lin file if it's different.
(defun c:XSteps ( / p1 p2 gn lt)
  (and (setq gn (list '(0 . "LINE") '(8 . "02-Steps") (cons 6 (setq lt "Dash Dash 1")) '(48 . 0.01)))
       (or (tblsearch "ltype" lt)
	   (command "._-linetype" "_load" lt "acadiso.lin" "")
	   (prompt (strcat "\n'" lt "' LT loading failed.")))
       (setq p1 (getpoint "\nSpecify first point: "))
       (setq p2 (getpoint p1 "\nSpecify second point: "))
       (entmake (append gn (list (cons 10 (trans p1 1 0))
				 (cons 11 (trans p2 1 0)))))
       (entmake (append gn (list (cons 10 (trans (list (car p1) (cadr p2)) 1 0))
				 (cons 11 (trans (list (car p2) (cadr p1)) 1 0))))))
  (princ)
Message 13 of 24
zaid.k3112
Hey bro.. thanks a lot. this is exactly what i needed. Thanks bro ❤️
Message 14 of 24
Sea-Haven
My 2 pt $0.05 version
(defun c:xmarksthespot ( / pt1 pt2 mp )
(setq pt1 (getpoint "\nPick point 1 ") pt2 (getpoint "\nPick point 2 "))
(setq mp (mapcar '* (mapcar '+ pt1 pt2) '(0.5 0.5)))
(command "line" pt1 pt2 "")
(command "Mirror" "l" "" mp (setq mp (mapcar '+ mp '(1.0 0.0 0.0))) "N")
(c:xmarksthespot)
Message 15 of 24
Kent1Cooper
Here's another way to draw the Lines, given that p1 and p2 are established:
  (command "_.line" p1 p2 "" "_.line" ".x" p1 p2 ".y" p1 p2 "")
Kent Cooper, AIA
Message 16 of 24
Kent1Cooper
@zaid.k3112 wrote:
Hello, I need a simple lisp which lets me select a 2 points i.e. a rectangle in which it will make cross lines ....
How about one pick inside any four-sided closed area [rather than two picks at opposite corners], and the ability to do that in as many of them as you want in one running of the command?  In simplest terms:
(defun C:Xit (/ pt bnd)
  (command "_.layer" "_thaw" "YourLayer" "_make" "YourLayer" "_ltype" "YourLinetype" "" "")
  (while (setq pt (getpoint "\nPick inside four-sided area: "))
    (command "_.boundary" pt "")
    (setq bnd (entlast))
    (command
      "_.line" (vlax-curve-getPointAtParam bnd 0) (vlax-curve-getPointAtParam bnd 2) ""
      "_.line" (vlax-curve-getPointAtParam bnd 1) (vlax-curve-getPointAtParam bnd 3) ""
    (entdel bnd)
  ); while
  (command "_.layerp")
  (princ)
Edit the "YourLayer" [twice] and "YourLinetype" names as desired.  [One advantage of using a Layer command is that if the linetype is in the acad.lin / acadiso.lin file, it is not necessary for it to be already loaded in the drawing -- the Layer command will find it.]
It's up to you to pick only within the right kind of bounded area, but it could be expanded to verify certain things before trying to draw the Lines [e.g. success in the BOUNDARY command, four sides, all-straight-edges if you like, etc.).
It works in any shape of quadrilateral area, even if non-rectangular or non-orthogonal [either of which a MIRROR-based command or a two-points approach would get wrong].
Kent Cooper, AIA
Message 17 of 24
rbischoffatsr
Draws single polyline rectangle with X by picking two points.
(defun c:xbox (/ P1 P2 P3 P4)
;set rectangle points
(setq P1 (getpoint "\nPick corner: "))
(setq P3 (getcorner P1 "\nPick opposite corner: "))
(setq P2 (list (car P1) (cadr P3)))
(setq P4 (list (car P3) (cadr P1)))
(command ".PLINE" P1 P2 P3 P4 P2 P3 P1 P4 "")
(princ))
Message 18 of 24
Kent1Cooper
[That really doesn't do what they asked for, namely with the X of a different layer/linetype than the perimeter -- see the wording of Message 1 and the sample drawing at Message 9.]
Kent Cooper, AIA
Message 19 of 24
john.uhden
@zaid.k3112
I guess I'm late for the party AND didn't read your request very well.
But, anyway, here's something you might want to use in the future...
(defun c:CrissCross ( / *error* vars vals ss i ent layer p1 p2 p3 p4)
  ;; John F. Uhden, Sea Girt, NJ, USA
  ;; Program adds crossing lines from opposite corners of multiple
  ;; closed rectangular lightweight polylines
  ;; v1.0 (4-14-22)
  (gc)
  (vl-load-com)
  (princ "\nCrissCross v1.0 (c)2022, John F. Uhden")
  (defun *error* (error)
    (mapcar 'setvar vars vals)
    (vla-endundomark *doc*)
    (cond
      ((not error))
      ((wcmatch (strcase error) "*QUIT*,*CANCEL*"))
      (1 (princ (strcat "\nERROR: " error)))
    (princ)
  (setq vars '("cmdecho"))
  (setq vals (mapcar 'getvar vars))
  (or *acad* (setq *acad* (vlax-get-acad-object)))
  (or *doc* (setq *doc* (vla-get-ActiveDocument *acad*)))
  (vla-startundomark *doc*)
  (mapcar 'setvar vars '(0))
  (command "_.expert" (getvar "expert")) ;; dummy command
  (and
    (princ "\nSeclect rectangles...")
    (setq ss (ssget '((0 . "LWPOLYLINE")(90 . 4)(-4 . "&")(70 . 1))))
    (repeat (setq i (sslength ss))
      (setq ent (entget (ssname ss (setq i (1- i))))
            layer (assoc 8 ent)
      (mapcar 'set '(p1 p2 p3 p4)(mapcar 'cdr (vl-remove-if-not '(lambda (x)(= (car x) 10)) ent)))
      (entmake (list '(0 . "LINE")(cons 10 p1)(cons 11 p3) layer))
      (entmake (list '(0 . "LINE")(cons 10 p2)(cons 11 p4) layer))
  (*error* nil)
(defun c:CC ()(c:CrissCross))
John F. Uhden
Message 20 of 24
ronjonp
@john.uhden  FWIW ..  😀
The 'dummy' command' and the setvars are not useful. Even more so when command calls are not used and you're not resetting it to the original value.
