Simple Lisp for Cross lines between rectangle.
zaid.k3112
Message 1 of 24
zaid.k3112
Hello, I need a simple lisp which lets me select a 2 points i.e. a rectangle in which it will make cross lines in a desired layer with line type.
Replies (23)
Message 21 of 24
john.uhden
@ronjonp
No crucifixion, but I disagree.
Without the dummy command, and because there is no use of the (command) function elsewhere, you get this...
CrissCross v1.0 (c)2022, John F. Uhden
Seclect rectangles...
Select objects: Specify opposite corner: 3 found
Select objects:
Command:
Command:
i.e. a double "Command:"
I always include it by copying and pasting from another program 'cause I may not know yet if I will be using a (command) function.  It doesn't hurt anything and it's all within an undo group.
Oh, and BTW, the variables do get reset...
(defun *error* (error)
(mapcar 'setvar vars vals)
(vla-endundomark *doc*)
(cond
((not error))
((wcmatch (strcase error) "*QUIT*,*CANCEL*"))
(1 (princ (strcat "\nERROR: " error)))
(princ)
John F. Uhden
Message 22 of 24
ronjonp
@john.uhden I could have sworn last night that those vars were not being reset .. my bad 😲.
Anyhoo ... the dummy command still baffles me. I ran your code with and without and the prompts were identical.
Command: CRISSCROSS
Select rectangles...
Select objects: 1 found
Select objects:
Command:
Command: CRISSCROSS
Select objects:
Command:
Happy Friday!
Message 23 of 24
calderg1000
Regards @zaid.k3112
Maybe this code can help you
(defun c:Mirrline (/ p1 p2 m1 m2)
  (vl-cmdf "Layer" "s" "02-Steps" "Ltype" "Dash Dash 1" "" "")
  (setq p1 (getpoint "\nP1: ")
        p2 (getpoint p1 "\nP1: ")
  (vl-cmdf "pline" p1 p2 "")
  (vl-cmdf "chprop" (entlast) "" "S" 0.01 "")
  (setq m1 (mapcar '* (mapcar '+ p1 p2) '(0.5 0.5 0.))
        m2 (mapcar '+ m1 '(0. 1. 0.))
  (vl-cmdf "mirror" (entlast) "" "none" m1 "none" m2 "n")
  (princ)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 24 of 24
Kent1Cooper
Just be aware that this will work as expected if the rectangular area that you pick opposite corners of to put an X in is orthogonally oriented.  It will give incorrect results if it's at any non-orthogonal angle:
That's where routines that involve selecting a Polyline rectangle [when you can], or even a non-rectangular 4-sided closed Polyline such as a trapezoid, and use its vertices to draw the X, have an advantage.
[And, of course, edit the Layer name, linetype and scale factor to suit your needs.]
Kent Cooper, AIA
