Rotate UCS / view to object but restore UCSFollow to 0
SRSDS
Advisor Advisor
SRSDS
I use these three lisp commands to manipulate the view.
(defun c:UO()
(command "._UCSFollow" "1" "UCS" "N" "Ob" )
(defun c:UP()
(command "._UCSFollow" "1" "UCS" "P")
(defun c:UW()
(command "._UCSFollow" "1" "._UCS" "W" "._UCSFollow" "0" )
Is it possible to restore the UCSFollow system variable to "0" in UO command?
Using this line, the selection of an object seems to interfere with the set of commands.
(command "._UCSFollow" "1" "UCS" "N" "Ob" "._UCSFollow" "0" )
UW works fine. I guess because there is not object that needs selecting.
ВeekeeCZ
(defun c:UO()
(defun c:UP()
(defun c:UW()
(command "._UCSFollow" "1" "UCS" "N" "Ob" pause "._UCSFollow" "0" )
PAUSE for a (single) user input
I use this (in 2D)
(defun c:UCS_O (/ *error* vc vs)   ;object
  (setq vc (trans (getvar 'viewctr) 1 0)
	vs (getvar 'viewsize))
  (vla-startundomark (vla-get-activedocument (vlax-get-acad-object)))
  (command "_.UCS"  "_OB" pause
	   "_.PLAN" "_C"
	   "_.ZOOM" "_C" (trans vc 0 1) vs)
  (vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
  (command "_.REGEN")
  (princ)
SRSDS
Thank you so much. For years I've been wondering who (or what) is turning on UCSFollow in viewports causing that zoom extents problem. It's been me.
