Visual LISP, AutoLISP and General Customization
Sheet "##" of Sheets
22 REPLIES 22
Message 1 of 23
lylegrisso
1515 Views, 22 Replies
I'm trying to figure out how to get a lisp routine to change the ## from the "page" section to auto insert the page number (not "ctab" name) based on it's position in the layout tabs. I'm already using the lisp routine for the total number of pages and that is working great.
Tags (1)
22 REPLIES 22
Message 2 of 23
paullimapa
in reply to: lylegrisso
found this little lisp routine on this thread that returns the layouts in order:
(defun getLayoutOrderList( / lst mklist mappend flatten)
  (defun mklist (x) (if (listp x) x (list x)))
  (defun mappend (fn lst)(apply 'append (mapcar fn lst)))
  (defun flatten (expr)(mappend 'mklist expr))
  (vlax-for lay
    (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))
    (setq lst (cons (list (vla-get-taborder lay)(vla-get-name lay)) lst))
  (cdr(flatten(mapcar 'cdr (vl-sort lst '(lambda (a b) (< (car a)(car b)))))))
you can call the function like this (vl-position (getvar"ctab") (getLayoutOrderList)) and add 1 to it return the position
Paul Li
IT Specialist
@The Office
Message 3 of 23
pbejse
Curious, what is the field source for that total number of pages - " of 11" <--- ?
Message 4 of 23
ronjonp
Why not number them in the sheet set manager? It looks like you're already heavily using fields already.
If you want to do this with code try this. You'll need to supply the blockname of your attributed block and the tag you wish to fill out. IMO the sheet set manager is a bit tidier though.
(defun c:foo (/ a bn c e s tg)
  ;; Name of your attribute block
  (setq bn "TBINFO")
  ;; Name of the attribute tag to fill out
  (setq tg "SHEET#")
  (cond	((setq s (ssget "_X" (list '(0 . "INSERT") '(410 . "~Model") (cons 2 bn) '(66 . 1))))
	 (setq a (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_LAYOUT"))))
	 (foreach e (mapcar 'cadr (ssnamex s))
	   (setq c (dictsearch a (cdr (assoc 410 (entget e)))))
	   ;; Function not available in Bricscad
	   (setpropertyvalue e tg (itoa (cdr (assoc 71 c))))
  (princ)
Message 5 of 23
lylegrisso
in reply to: pbejse
pbejse
I'm using this lisp to get the total number
(vlr-command-reactor nil '((:vlr-commandWillStart . _totalLayoutsReactor)))
Message 6 of 23
lylegrisso
ronjonp
I'm not using the sheet set manager due to the client.
I tried your code (after changing the block name and attribute name) and it seems to bring up the visual LISP console, but it's not reacting to the drawing.
paulli_apa
your code didn't work with this either.
Message 7 of 23
paullimapa
Message 8 of 23
ronjonp
@lylegrisso
Post a sample drawing with your titleblock. For it to "react" to your drawing you'd need to include it in the "_totalLayoutsReactor" code that you already have.
Message 9 of 23
lylegrisso
@ronjonp
here is a sample dwg with my border.
also not sure if it matters but I'm using Acad 2023
Message 10 of 23
ronjonp
@lylegrisso wrote:
@ronjonp
Worked here see attached:
  (setq bn "BORDER")
  (setq tg "SHT")
  (princ)
I'm using AutoCAD 2023 as well.
Message 11 of 23
lylegrisso
@ronjonp
still can't seem to get it to work on my end. I'm not sure why, I copied the code and tried it but the dwg didn't change on my end and the dwg you gave back wouldn't go beyond 11 on the sheet number, even though the total number updated fine.
Message 12 of 23
ronjonp
@lylegrisso
You'd have to run the code again after you make changes .. the other "_totalLayoutsReactor" code you mentioned runs on a reactor which is code that "reacts" to changes/commands automatically.
Message 13 of 23
lylegrisso
@ronjonp
as you can see from this picture, this is what im getting every time i try to load it.
and then nothing from the dwg changes.
Message 14 of 23
ronjonp
Are you typing "foo" on the command line after you load it? It does not run automatically.
If you want it to run automatically after load then add this line at the end:
Message 15 of 23
paullimapa
Any reason why you don't want to run PageOf.vlx (my reply message 7)?
After loading the vlx, works pretty well on your SHT attribute.
The only thing you need to do is edit & remove the text you don't want
Paul Li
IT Specialist
@The Office
Message 16 of 23
ronjonp
in reply to: paullimapa
@paullimapa
For me I don't run compiled code unless I created it and or I completely trust the author. Compiled code for this simple task is unnecessary IMO.
Message 17 of 23
paullimapa
in reply to: ronjonp
I typically don't like to use compiled code either. But since this little vlx file gets the job done, I thought I share it so OP is aware.
Paul Li
IT Specialist
@The Office
Message 18 of 23
Sea-Haven
Another example it uses the layout name pulling the number from it, but the layout number could be used instead.
;;-------------------=={ Parse Numbers }==--------------------;;
;;  Parses a list of numerical values from a supplied string. ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  s - String to process                                     ;;
;;  Returns:  List of numerical values found in string.       ;;
(defun LM:ParseNumbers ( s )
    (lambda ( l )
      (read
        (strcat "("
          (vl-list->string
            (mapcar
              (function
                (lambda ( a b c )
                  (if
                    (or
                      (< 47 b 58)
                      (and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
                      (and (= 46 b) (< 47 a 58) (< 47 c 58))
                    b 32
              (cons nil l) l (append (cdr l) (list nil))
    (vl-string->list s)
; end of lee-mac
; start of update
(DEFUN ah:sheetupdate1 ( / DOC LAY PLOTABS LEN TABNAME DWGNUM OLDTAG1 SHEETNUM NEWSTR1 ATT ss1)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(setq plotabs '())
(vlax-for lay (vla-get-Layouts doc)
  (setq plotabs (cons (vla-get-name lay) plotabs))
(setq len (length plotabs))
(setq x 0)
(setq oldtag1 "SHTNO.") ;attribute tag name change to suit
(repeat len
  (setq tabname (nth x plotabs))
  (if (/= tabname "Model")
    (progn
      (setvar 'ctab tabname)
      (command "pspace")
      (setq ss1 (ssget "x"  (list (cons 0 "INSERT") (cons 2 "Your title block name")(cons 410 tabname))))
      (setq sheetnum  (abs (car (Lm:parsenumbers tabname))))
      (setq newstr1 (STRCAT (rtos sheetnum 2 0) " of " (RTOS (- LEN 1) 2 0)))
      (foreach att (vlax-invoke (vlax-ename->vla-object (ssname SS1 0 )) 'getattributes)
        (if (= oldtag1 (strcase (vla-get-tagstring att)))
        (vla-put-textstring att newstr1)
(setq x (+ x 1))
) ; end repeat
; end defun ah
(ah:sheetupdate1)
Message 19 of 23
paullimapa
If having a field (automatic update) is not a requirement, then this works.
I modified it to fit your title block name & attribute.
It'll automatically fill out sheet #. But if you move the layout tabs around, you'll have to re-run tabnumber command.
(defun c:tabnumber (/ _put a blk_name e i n s tag_name)
  (defun _put (blk tag val)
    (vl-some
      '(lambda (x) (and (wcmatch (vla-get-tagstring x) (strcase tag)) (vla-put-textstring x val)))
      (vlax-invoke blk 'getattributes)
  ;; Edit below for your use
  (setq blk_name "BORDER" ; "YOURTITLEBLOCKNAME"
  tag_name "SHT" ; "YOURATTRIBUTETAG"
  (setq i (itoa (length (layoutlist))))
  (vlax-for l (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))
    (setq a (cons (list (vla-get-name l) (vla-get-taborder l)) a))
  (if (setq s (ssget "_A" (list '(0 . "INSERT") (cons 2 blk_name) '(66 . 1))))
    (foreach b (mapcar 'cadr (ssnamex s))
      (if (setq n (cadr (assoc (cdr (assoc 410 (entget b))) a)))
; (_put (vlax-ename->vla-object b) tag_name (strcat "Page " (itoa n) " of " i))
  (_put (vlax-ename->vla-object b) tag_name (itoa n))
  (princ)
Paul Li
IT Specialist
@The Office
Message 20 of 23
lylegrisso
okay, i see that now from your code. thanks and it works. thank you very much.
Forma Design Contest
AutoCAD Beta
