merge lists and sort by numbers
sunlight1
sunlight1
HI
i need help to organize and merge 2 lists.
for example i have list 1   (3 1 7 5 9)
and list A                            (C K R A T)
i need to merge them together, so 3 must come with C , and 1 must come with K etc...
for example (3C 1K 7R 5A 9T)
and then  i want to sort them by numbers.   so (print lists) will be (1K 3C 5A 7R 9T)
and (car lists) will be (1K)
P.S  I actually have dates and names but it's simpler that way
tnx for helping
ВeekeeCZ
(3 1 7 5 9) are strings or integers?
(C K R A T) are strings, right? '("C" "K" ...)
anyways...
(defun :sortmerge (nlst alst)
  (mapcar '(lambda (l) (strcat (vl-princ-to-string (car l)) (cdr l)))
	  (vl-sort (mapcar 'cons nlst alst) '(lambda (n1 n2) (< (car n1) (car n2))))))
> (:sortmerge '(3 1 7 5 9) '("C" "K" "R" "A" "T"))
> ("1K" "3C" "5A" "7R" "9T")
or...
> (:sortmerge '("3" "1" "7" "5" "9") '("C" "K" "R" "A" "T"))
martti.halminen
The easiest way probably is first sorting the numbers using VL-SORT-I, and then using MAPCAR and NTH on the index file to pick the items to combine.
sunlight1
tnx a lot ! working great
yangguoshe
(setq m'("3" "1" "7" "5" "9" ) n'("C" "K" "R" "A" "T" ))
(vl-sort(mapcar'strcat m n)'<)
return:  ("1K" "3C" "5A" "7R" "9T")
calderg1000
Regards @sunlight1
Try this...
(setq l1 '(3 1 7 5 9))
(setq l2 '(C K R A T))
(setq l12 (mapcar '(lambda(x y) (strcat (itoa x) (vl-symbol-name y))) l1 l2))
(setq lf (vl-sort l12 '(lambda(x y) (< x y))))
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
