Insert several DXF with original coordinates
Egd4
Message 1 of 8
Egd4
First, excuse my english, I'm french 🙂
I'm a total noob in autocad, but for work I have to import several DXF files into one DWG. I found a little script working, my dxf files are all merged into one dwg but original coordinates are lost.
(defun c:DXFIMPORTALL (/ directory files)
(setq directory "D:\\3D\\273_Port_Valais\\01_ENTREES\\SWISS_BUILDINGS")
(if (setq files (vl-directory-files directory "*.dxf" 1))
(foreach dxf files
(command "_.-insert" (strcat directory "\\" dxf) '(0. 0. 0.) """""")
(princ "\n No DXF files found into that folder !")
(princ)
I don't know how to obtain the same result has with a CTRL+C / Paste to original coordinates.
Thanks in advance for help!
Replies (7)
Message 2 of 8
hmsilva
(foreach dxf files
(princ)
@Egd4
Try to change
to
(command "_.-insert" (strcat directory "\\" dxf) "_non" '(0. 0. 0.) """""")
Hope this helps,
Henrique
Message 3 of 8
Egd4
Thanks for the help!
Unfortunately, the result is the same.
For example, instead of having an original point such as
it turns to
Message 4 of 8
hmsilva
Diferent units...
_$ (/ 2551307.777 6.4803e+07)
0.0393702
1.00000 mm to in = 0.0393702
Objects are scaled when inserted into a drawing in AutoCAD products
Hope this helps,
Henrique
Message 5 of 8
Egd4
allriiiiiiiiiiiiiiiiiiiiiiiiiiiiiiight! You're a genius...(to me 😉)
Is there any solution to include the conversion (or not to convert) in my little lisp code?
Message 6 of 8
hmsilva
From my previous post:
"To deactivate automatic scaling of inserted objects:
  1. At the command prompt in AutoCAD, enter INSUNITS.
  2. Change the value to 0 (zero).
  3. Repeat this for INSUNITSDEFSOURCE and INSUNITSDEFTARGET."
Hope this helps,
Henrique
Message 7 of 8
Egd4
You're a life savior! Thank you very much for your involvement!
Message 8 of 8
hmsilva
You're welcome, @Egd4
Glad I could help
Henrique
