@ryanatkins49056 wrote:
... it will print to the command line the angle it is drawn at.
... but always and only the angle as measured CCW from to-the-right as zero degrees. Using entity data, it is unaffected by the ANGBASE and/or ANGDIR System Variable settings. Likewise with the VLA and (getpropertyvalue) approaches' "Angle" properties.
However, all that is really needed for a Line is to have ANGBASE/ANGDIR set as you want them, and simply select the Line and look at its angle as reported in the Properties palette. That does honor whatever settings you have in those System Variables. No command, much less any customization, is required. But if you don't mind invoking a command, a simple LIST command also honors those settings in its report of the angle of a Line.
Kent Cooper, AIA
