Give Line direction clock wise
avinash00002002
avinash00002002
Hi!
I need help that I have select a line at any direction it always give me clockwise direction p1 and p2 point.
Avinash
Moshe-A
@avinash00002002  hi
Not sure what you mean but if you have angle in CCW, subtract 270 [ (* pi 1.5) ] from it and you will have CW
Moshe
autoid374ceb4990
A LINE has a beginning point and end point. Were the lines drawn P1 to P2?  Try drawing one P2 to P1.
Kent1Cooper
If I understand correctly what you want, read about the ANGBASE and ANGDIR System Variables.  With them, you can have angles measured in relation to any direction you want to be zero degrees [for example, upward instead of the default rightward direction], and in the clockwise direction instead of the default counter-clockwise.  No customization is needed.
Kent Cooper, AIA
