How to adjust tile size in dcl
tim11_manhhieu
tim11_manhhieu
How to shorten the Ref. Drawing Edit box and lengthen the Model code edit box.
I tried changing the width =  but nothing changed.
Ref. drawing edit box and model code edit box
: row {
  : boxed_column { label = "KHUNG TRAI";
    : text { label = "REF. DRAWING";}
    : edit_box { key = "REFDRAWING";}
  : boxed_column {
    : text { label = "MODEL CODE";}
    : edit_box { key = "MODELCODE";}
.dcl
newform_dialog : dialog {
  label = "XXX";
: row {
//KHUNG TREN---------------------------
  : boxed_row { label = "KHUNG DUOI";
    : row {
      : column {
        : text { label = "TITLE";}
        : text { label = "SUB TITLE";}
        : text { label = "DRAWING NO.";}
        : text { label = "REVISION";}
      : column {
        : edit_box { key = "TITLEKD";}
        : edit_box { key = "SUBTITLE";}
        : row {
          : edit_box { key = "DRAWINGNO";}
          : button { label = "Get"; }
        : edit_box { key = "REVISION";}
  //KHUNG DUOI--------------------------
  : boxed_row { label = "KHUNG TREN";
    : row {
      : column {
        : text { label = "CTG.";}
        : text { label = "REMARKS";}
        : text { label = "PREP.";}
        : text { label = "M.F.";}
      : column {
        : edit_box { key = "CTG";}
        : edit_box { key = "TITLEKT";}
        : edit_box { key = "REMARKS";}
        : edit_box { key = "PREP";}
        : edit_box { key = "MF";}
// O Reference drawing va o model code
: row {
  : boxed_column {
//KHUNG TEN------------------------------------
: boxed_row { label = "KHUNG TEN";
  : row {
        : column {
          : text { label = "APPROVED";}
          : text { label = "REVIEWED";}
          : text { label = "DATE";}
        : column {
          : edit_box { key = "APPROVED";}
          : edit_box { key = "REVIEWED1";}
          : edit_box { key = "DATE";}
  : column {
    : row {
          : column {
            : text { label = "PREPARED";}
          : column {
            : edit_box { key = "REVIEWED2";}
            : edit_box { key = "PREPARED";}
    : row {
            : button { label = "Today";}
            : button { label = "Assy";}
            : button { label = "Part";}
: row {
  ok_button;
  cancel_button;
  : button { label = "About me";}
tim11_manhhieu
Sorry for wasting time, I can adjust the length of the box with edit_width = .
However, there is a problem that the ref drawing box is not aligned to the left as set
I tried aligning to the right and it is OK.
: row {
  : boxed_column { label = "KHUNG TRAI";children_alignment =left;
    : edit_box { key = "REFDRAWING";edit_width =10;}
  : boxed_column { children_alignment =left;
paullimapa
add children_fixed_width = true;
  : boxed_column { label = "KHUNG TRAI"; children_alignment = left; children_fixed_width = true;
Then it'll look like this:
Paul Li
IT Specialist
@The Office
