Give Line direction clock wise
avinash00002002
Message 1 of 32
avinash00002002
Hi!
I need help that I have select a line at any direction it always give me clockwise direction p1 and p2 point.
Avinash
Replies (31)
Message 2 of 32
Moshe-A
@avinash00002002  hi
Not sure what you mean but if you have angle in CCW, subtract 270 [ (* pi 1.5) ] from it and you will have CW
Moshe
Message 3 of 32
autoid374ceb4990
A LINE has a beginning point and end point. Were the lines drawn P1 to P2?  Try drawing one P2 to P1.
Message 4 of 32
Kent1Cooper
If I understand correctly what you want, read about the ANGBASE and ANGDIR System Variables.  With them, you can have angles measured in relation to any direction you want to be zero degrees [for example, upward instead of the default rightward direction], and in the clockwise direction instead of the default counter-clockwise.  No customization is needed.
Kent Cooper, AIA
Message 5 of 32
Sea-Haven
Like @Kent1Cooper if you type Units and in ACAD the angular values are on the right if I remember correctly. This is same thing but in Bricscad. The 90 sets the 0 angle to be North.
Message 6 of 32
ryanatkins49056
Not entirely sure what you're after but I'll take a guess to try and help a things along.
(defun c:getlineangle ( / lineitem)
  (setq lineitem (entget (car (entsel))))
  (* (angle (cdr (assoc 10 lineitem)) (cdr (assoc 11 lineitem))) (/ 180 pi))
);(defun)
 The above will only work if you select a line but it will print to the command line the angle it is drawn at.
As always if you could provide more information as to what exactly you're after or trying to do would be helpful.
Message 7 of 32
Kent1Cooper
@ryanatkins49056 wrote:
... it will print to the command line the angle it is drawn at.
... but always and only the angle as measured CCW from to-the-right as zero degrees.  Using entity data, it is unaffected by the ANGBASE and/or ANGDIR System Variable settings.  Likewise with the VLA and (getpropertyvalue) approaches' "Angle" properties.
However, all that is really needed for a Line is to have ANGBASE/ANGDIR set as you want them, and simply select the Line and look at its angle as reported in the Properties palette.  That does honor whatever settings you have in those System Variables.  No command, much less any customization, is required.  But if you don't mind invoking a command, a simple LIST command also honors those settings in its report of the angle of a Line.
Kent Cooper, AIA
Message 8 of 32
Kent1Cooper
@Sea-Haven wrote:
.... if you type Units and in ACAD the angular values are on the right if I remember correctly. ...
Here's where they are in Acad2026:
Yellow highlighting shows the initial defaults, but set them however you prefer.
Kent Cooper, AIA
Message 9 of 32
avinash00002002
Hi!
I have attached sample line drawing.
Avinash
Message 10 of 32
Moshe-A
@avinash00002002
check now the lines angle and tell us if this is what you after (your fixed file is attached)
Message 11 of 32
avinash00002002
Lines are at any angle it may be vertical, Horizontal , no prediction for angle.
Message 12 of 32
Moshe-A
Did you check lines angle they are now in CW - isn't it what you want?
Message 13 of 32
avinash00002002
If we create a horizontal line from left to right and right to left in both cases it will change the p1, p2 point location.
Message 14 of 32
Moshe-A
@avinash00002002 ,
i still do not understand what you want and how this related to CCW / CW
you want a tool that even if you draw a line from right to left (or top to bottom) it will reverse the points ?
why it is matter?
Message 15 of 32
komondormrex
hey,
check this one
(defun c:get_line_angle (/ line_object delta_y_x)
	(setq line_object (vlax-ename->vla-object (car (entsel "\nPick line: ")))
	      delta_y_x (reverse (mapcar '- (vlax-get line_object 'startpoint)  (vlax-get line_object 'endpoint) '(0 0)))
  	(if (zerop (cadr delta_y_x))
	  (print (angtos (* -1.5 pi) 1 2))
	  (print (angtos (- (* 2 pi) (atan (apply '/ delta_y_x))) 1 2))
  	(princ)
Message 16 of 32
avinash00002002
Thanks for your prompt reply, I need points like p1 and p2 at the end of line.
Message 17 of 32
ryanatkins49056
Hang on @avinash00002002 I think I may have it.
Are you asking for the text labels P1 and P2 to be inserted at the end of each line?
Message 18 of 32
avinash00002002
NO, I don't need labels I need only define p1  and p2 points.
Message 19 of 32
ryanatkins49056
Then we all still need a little help as to what exactly you want.
You've provided us with a drawing that has a whole heap of lines at varying angles and the only common factor is that the P1 is on the left of every line.
You've now stated you only need to define P1 and P2 points.
Can you explain step by step what it is exactly you are trying to achieve?
Message 20 of 32
avinash00002002
I want to achieve that I need p1 point at the left side and p2 point is right side for identify cut at p1 point has left side and if cut at point p2 then it identify right side always.
