Export polyline data (area, layer and inner text) to excel
Message 1 of 180
Hello, everyone!
I am searching for a lisp that can find all closed polylines in a drawing and export to excel their following information:
-Area of each closed polyline
-Layer in which the polyline resides
-Text inside each polyline
I have a building plan with polylines enclosing each room and the corresponding room text number also inside the polyline. I am looking for a lisp that can export to excel a table like this:
Text inside polylinePolyline Area (m2)Layer
"Room_1.1"10 m2Room_Layer
"Room_1.2"5 m2Room_Layer
"Room_1.3"5 m2Room_Layer
 -20 m2Floor_Layer
The polylines and room text numbers are located in different layers.
One of the polylines (last row in the table) encloses the whole building which means that there is more that one text inside it. For this single polyline, I only need its area and layer (text not needed).
I am fairly new to lisp creation so any help you can provide me would be highly appreciated!
Thanks in advance!
Replies (179)
Message 41 of 180
pbejse
This
(strcat (rtos (Cadr itm) 2 2) " m2")
to
(strcat (vl-string-translate "." "," (rtos (Cadr itm) 2 2)) " m2")
Good job buddy
Message 42 of 180
wacho31
You are magician! works perfect!
Thank you
Here is a result (attachments)
Message 43 of 180
wacho31
Is it possible to add below exported data in csv file
- in first column:
string "Total area:"
- in second column:
value with sum of areas
Thank You!
Message 44 of 180
jalal.mousa
Hi There,
can you edit lisp to add column for perimeter of room beside area ?
@pbejse wrote:
@Anonymous wrote:
Just one more detail, would it be possible to add a 4th column to the table with the information on whether the polylines are closed or not (field "Closed" in "Misc" properties, attached image).
Here you go.
(defun c:EPD (/ ss i area layer all_data pts csv_file openfile) ; Export Polyline Data
;;			pBe Sep 2018			;;
  (if (and
        (setq all_data nil
              ss       (ssget '((0 . "LWPOLYLINE")))
	        (repeat (setq i (sslength ss))
	          (setq e     (ssname ss (setq i (1- i)))
	                area  (vlax-curve-getarea e)
	                layer (cdr (assoc 8 (setq ent (entget e))))
	                cl_op (cdr (assoc 70 ent))
	                pts   (mapcar 'cdr
	                              (vl-remove-if-not
	                                '(lambda (d)
	                                   (= 10 (car d))
	                                ent
	          (if (setq ssText (ssget "_CP" pts '((0 . "TEXT"))))
	            (setq all_data
	                   (cons
	                     (list (if (= (sslength ssText) 1)
	                             (cdr (assoc 1 (entget (ssname ssText 0))))
	                           area
	                           layer
	                           (if (zerop ( logand 1 cl_op)) "No" "Yes")
	                     all_data
               all_data
	        (setq csv_file (getfiled "Save CSV File"
	                                 (strcat
	                                   (getvar 'dwgprefix)
	                                   (vl-filename-base (getvar 'dwgname))
	                                   ".csv"
	                                 "csv"
	                                 45
        (progn
          (setq openfile (open csv_file "w"))
          (write-line
            "Text inside polyline,Polyline Area (m2),Layer,Closed"
            openfile
          (foreach itm (vl-sort all_data
                                '(lambda (a b) (< (Cadr a) (cadr b)))
            (write-line
              (Strcat (Car itm)
                      (caddr itm)
                      (last itm)
              openfile
          (close openfile)
          (startapp "notepad" csv_file)
  (princ)
Message 45 of 180
pbejse
I assume you meant "length", it is the same is it not? Can you confirm that it is.
Message 46 of 180
jalal.mousa
Yes you are right, once you use polyline it will give you in properties area and length
I would like to get :
1. Text inside polyline
2. Polyline layer name
3. Area (in sf or sm depends on inits)
4. Length (in lf or lm)
[cid:[email protected]]
Message 47 of 180
CLL_PBE
Sure
command: TPAL [ attached file ]
Result:
Text inside polyline,Layer,Polyline Area (m2),Length
Single line 2,Alayer,248.44 m2,69.41
Single line 5,AnotherLayer,226.73 m2,60.32
Single line 4,AndAnother,610.96 m2,98.92
Single line 1,YetAnotherLayer,215.65 m2,58.78
HTH
Message 48 of 180
jalal.mousa
Hi There,
Thanks a lot for your help this is great, but I am facing trouble with using this code with all polylines I draw
It loads lisp successfully but when I run it and select objects it won't wright results to notepad/excel
When I tried lisp on sample provided it works
Any thoughts on why it is not working?
Please see attached file with 3 rooms I draw (room 100,102,103) that lisp won't work with
I am using Autocad 2015 not sure if it's matters
Thanks in advance
Message 49 of 180
pbejse
Those must be invisible drawing files I've been hearing about in the past 3 months Smiley Very Happy
Try attaching the file again @jalal.mousa .
Message 50 of 180
jalal.mousa
Hi not sure why it did not attached it maybe because i reply in e-mail
please see attached hope it will work
Message 51 of 180
CLL_PBE
On your previous post, you posted a code that you want to modify, and it shows below.
So...
change
To
(setq ssText (ssget "_CP" pts '((0 . "MTEXT"))))
HTH
Message 52 of 180
jalal.mousa
this solution works perfect
thanks a lot
I was wondering if I can ask for last few things
please see attached file that different polyline overlap each other in few locations
would it be possible to provide  a count column and total length where they overlap ?
so in attached file you will see notes I put to clarify above
Message 53 of 180
jalal.mousa
sorry for bothering you again
can you add:
  1. would it also possible to list all text that have no polyline around
  2. add column beside text content for text layer name
in our example the answer would be ;
  1. Text with no poliyline around ( 101)
  2. name of layer (0)
many thanks in advance
Message 54 of 180
jalal.mousa
can you add:
Message 55 of 180
CLL_PBE
thanks a lot
I was wondering if I can ask for last few things..
can you add:
You can ask by all means.
Yes  Yes, and Yes
Would you like some fries to go with that lisp?
Message 56 of 180
jalal.mousa
LOL
I know it is too much to ask
Message 57 of 180
pbejse
@jalal.mousa wrote:
LOL
Just playing with you, I'll post the modified code later
Cheers
Message 58 of 180
jalal.mousa
sorry to bother you again
i just notice that :
  1. if there is more than one text inside closed polyline it won't grab any of the text but -
  2. it won't grab closed polyline if no text inside
  3. it won't grab text if no closed polyline around it (this mentioned probably part of last email)
is this something can be fixed ?
Message 59 of 180
pbejse
Are you serious right now?
The answer is still YES
But first
Deposit 50 USD to this account number
(73 39 109 32 97 98 117 115 105 110 103 32 121 111 117 114 32 107 105 110 100 110 101 115 115)
Message 60 of 180
jalal.mousa
Omg 😴
