Export polyline data (area, layer and inner text) to excel
Message 1 of 180
Hello, everyone!
I am searching for a lisp that can find all closed polylines in a drawing and export to excel their following information:
-Area of each closed polyline
-Layer in which the polyline resides
-Text inside each polyline
I have a building plan with polylines enclosing each room and the corresponding room text number also inside the polyline. I am looking for a lisp that can export to excel a table like this:
Text inside polylinePolyline Area (m2)Layer
"Room_1.1"10 m2Room_Layer
"Room_1.2"5 m2Room_Layer
"Room_1.3"5 m2Room_Layer
 -20 m2Floor_Layer
The polylines and room text numbers are located in different layers.
One of the polylines (last row in the table) encloses the whole building which means that there is more that one text inside it. For this single polyline, I only need its area and layer (text not needed).
I am fairly new to lisp creation so any help you can provide me would be highly appreciated!
Thanks in advance!
Replies (179)
Message 2 of 180
devitg
Please upload your sample.dwg
Message 3 of 180
devitg
Message 4 of 180
Hello, devitg!
Thanks for your quick response. I send you the sample.dwg in attachment.
For this sample drawing, I would like the lisp to create a table in excel similar to the following:
Polyline nºText inside polylinePolyline Area (m2)Polyline Layer
11.151.34 m2Room Layer
21.228.75 m2Room Layer
31.314.41 m2Room Layer
4-100.75 m2Floor Layer
Thanks in advance!
Message 5 of 180
pbejse
@Anonymous wrote:
Polyline nº Text inside polyline Polyline Area (m2) Polyline Layer
1 1.1 51.34 m2 Room Layer
2 1.2 28.75 m2 Room Layer
3 1.3 14.41 m2 Room Layer
4 - 100.75 m2 Floor Layer
Try this [results in CSV format]
(defun c:demo (/ ss i area layer all_data pts csv_file openfile)
;;			pBe Sep 2018			;;
  (if (and
        (setq all_data nil
              ss       (ssget '((0 . "LWPOLYLINE")))
        (repeat (setq i (sslength ss))
          (setq e     (ssname ss (setq i (1- i)))
                area  (vlax-curve-getarea e)
                layer (cdr (assoc 8 (setq ent (entget e))))
                pts   (mapcar 'cdr
                              (vl-remove-if-not
                                '(lambda (d)
                                   (= 10 (car d))
                                ent
          (if (setq ssText (ssget "_CP" pts '((0 . "TEXT"))))
            (setq all_data
                   (cons
                     (list (if (= (sslength ssText) 1)
                             (cdr (assoc 1 (entget (ssname ssText 0))))
                           area
                           layer
                     all_data
        (setq csv_file (getfiled "Save CSV File"
                                 (strcat
                                   (getvar 'dwgprefix)
                                   (vl-filename-base (getvar 'dwgname))
                                   ".csv"
                                 "csv"
                                 45
        (progn
          (setq openfile (open csv_file "w"))
          (write-line
            "Text inside polyline,Polyline Area (m2),Layer"
            openfile
          (foreach itm (vl-sort all_data
                                '(lambda (a b) (< (Cadr a) (cadr b)))
            (write-line
              (Strcat (Car itm)
                      (strcat (rtos (Cadr itm) 2 2) " m2")
                      (caddr itm)
              openfile
          (close openfile)
          (startapp "notepad" csv_file)
  (princ)
HTH
Message 6 of 180
Thank you very much, pbejse!! You're a lifesaver, that's exactly what I needed.
Just one more detail, would it be possible to add a 4th column to the table with the information on whether the polylines are closed or not (field "Closed" in "Misc" properties, attached image).
Text inside polylinePolyline Area (m2)Polyline LayerClosed
1.151.34 m2Room LayerYes
1.228.75 m2Room LayerYes
1.314.41 m2Room LayerYes
-100.75 m2Floor LayerYes
Once again, that you very much for any help you can provide
Message 7 of 180
pbejse
Here you go.
(defun c:EPD (/ ss i area layer all_data pts csv_file openfile) ; Export Polyline Data
;;			pBe Sep 2018			;;
  (if (and
        (setq all_data nil
	                cl_op (cdr (assoc 70 ent))
	                pts   (mapcar 'cdr
	                              (vl-remove-if-not
	                                '(lambda (d)
	                                   (= 10 (car d))
	                                ent
	            (setq all_data
	                   (cons
	                           area
	                           layer
	                           (if (zerop ( logand 1 cl_op)) "No" "Yes")
	                     all_data
               all_data
	                                 (strcat
	                                   (getvar 'dwgprefix)
	                                   ".csv"
	                                 "csv"
	                                 45
        (progn
          (write-line
            "Text inside polyline,Polyline Area (m2),Layer,Closed"
            openfile
            (write-line
              (Strcat (Car itm)
                      (caddr itm)
                      (last itm)
              openfile
          (close openfile)
  (princ)
Message 8 of 180
It works perfectly! You never fail to deliver.
Thank you very much for your valuable help!!
Message 9 of 180
emsquare.arch
Hi
If you add some more lines as per my requirement. Procedure will be same but with slight change. I need unit area , Duct area ( any polyline inside the unit will be duct) and Balconies area ( any polyline outside the unit will be balcony but outside polyline must snap to unit). Please refer the attached
Message 10 of 180
Hello
Text inside polylinePolyline Area (m2)Polyline LayerClosedHandle ID
1.1, 1.2, 1.3100.75 m2Floor LayerYes
Message 11 of 180
devitg
No comments .
It´s easy to ask by step, when it would be better to ask the whole stair.
Message 12 of 180
pbejse
@Anonymous wrote:
How would you want to label those polylines on the table? as blank or a dash perhaps?
Message 13 of 180
Hello pbejse,
The polylines without texts can be labelled with a dash.
Thank you very much for asking!
Message 14 of 180
pbejse
True.
;;			pBe Sep 2018			;;
  (if (and
        (setq all_data nil
                     ent   (entget e)
                     data  (mapcar '(lambda (d)(cdr (assoc d ent))) '( 8 70 5))
	                pts   (mapcar 'cdr
	                              (vl-remove-if-not
	                                '(lambda (d)
	                                   (= 10 (car d))
	                                ent
		(setq all_data
	                   (cons
	                     (list
				(cond
                              		((null (setq ssText (ssget "_CP" pts '((0 . "TEXT")))))	"-"
                                   	((= (sslength ssText) 1)
                                   	((substr
					   (apply 'strcat
					      (mapcar '(lambda (st)
					                 (strcat " | " st))
							(vl-sort
							  (mapcar '(lambda (s)
							             (cdr (assoc 1 (Entget s)))
							          (vl-remove-if 'listp (mapcar 'cadr (ssnamex ssText)))
							  (function (lambda (a b)
							              (< a b)
						   4
	                           area
	                           (car data)
	                           (if (zerop ( logand 1 (cadr data))) "No" "Yes")
                            	  (caddr data)
	                     all_data
               all_data
	                                 (strcat
	                                   (getvar 'dwgprefix)
	                                   ".csv"
	                                 "csv"
	                                 45
        (progn
          (write-line
            "Text inside polyline,Polyline Area (m2),Layer,Closed,Handle"
            openfile
            (write-line
              (Strcat (Car itm)
                      (caddr itm)
                      (cadddr itm)
                      (last itm)
              openfile
          (close openfile)
  (princ)
I used the pipe " | " as the separator for collected names, the comma symbol is used for delimiter for the csv file.
1.1 | 1.2 | 1.3 187.25 m2 Floor Layer Yes 8BBD
HTH
Message 15 of 180
Message 16 of 180
This code is what I've been looking for a while.
I'm new to lisp coding. What line(s) do I have to change to get it to list the areas in square feet?
Thanks in advance and thanks for sharing your knowledge!
Message 17 of 180
pbejse
Are you referring to the unit string?
This
to
(strcat (rtos (Cadr itm) 2 2) " sq. ft")
or you need conversion?
Message 18 of 180
I need the conversion to square feet.
I tried to come up with it myself but I could not get the math right.
Thanks!
Message 19 of 180
pbejse
Thanks!
Any of this two will work
(strcat (rtos
          (* (Cadr itm) 10.7639104)  2 2) " sq. ft")
or
(strcat (rtos
          (cvunit (Cadr itm) "sq meter" "sq feet")
              2 2) " sq. ft")
HTH
Message 20 of 180
Thank you - but I didn't explain my situation completely.
The AutoCAD drawings I work with are drawn in architectural units.
So when I switched out your conversion code I did not get the right results.
For a 10'-0" x 20'-0" room I get 310000.62 sq. ft.
None of my drawings are in metric, so I guess I can not use your code.
Thank you for your input in trying to solve my problem.
