Pre-Naming a Layer before runing the Layer Merge Lisp
gustavobernardi
gustavobernardi
Hi. I'm developing a lisp to rename layers (known names). The problem is that when I try to put the Layer names on a shorter variable, it doesn't work.
This one works fine:
(if
		(and(tblsearch "layer" "Arquitetônico - Paredes")(tblsearch "layer" "ARQ - Paredes Alvenaria"))
		(progn
			(command "Laymrg") (foreach e '("Arquitetônico - Paredes") (if (tblsearch "LAYER" e)(command "_Name" e)))(command "" "_N" "ARQ - Paredes Alvenaria" "_Y")
			(command "_.-PURGE" "_La" "Arquitetônico - Paredes" "_N")
And this one doesn't work:
(setq oldname "Arquitetônico - Paredes")
(setq newname "ARQ - Paredes Alvenaria")
(if (and(tblsearch "layer" oldname)(tblsearch "layer" newname)) (progn (command "Laymrg") (foreach e '(oldname) (if (tblsearch "LAYER" e)(command "_Name" e)))(command "" "_N" newname "_Y") (command "_.-PURGE" "_La" oldname "_N") ) )
Isn't impossible to do the first way, but for several layers it will be interesting to just give the names and run the routine for each one.
TIA
ВeekeeCZ
You gotta evaluate a variable, not just quote.
'(oldname) -> (list oldname)
gustavobernardi
Why this code sometime renames OK and sometimes screws up with the latin characters.
(setq oldname "Wipeout")(setq newname "Máscara")
(if(and(tblsearch "layer" oldname)(not(tblsearch "layer" newname)))
			(COMMAND "._-RENAME" "LA" OLDNAME NEWNAME)
Sometimes the new name is "Máscara"
ВeekeeCZ
I would suggest you ask about this language related issue to the Portuguese speaking forum.
In general, I would recommend avoiding use such letters, you will prevent a lot of troubles.
gustavobernardi
I solved the problem loading the Layer names from a TXT in inspite of stocking them in the Autolip code.
gustavobernardi
I have solved the question.
It is possible loading from a text file or use directly on the lisp file, whatever.
But the source (lisp or txt file) needs to be saved in ANSI Codification.
