Here's a way.
;;; PlineOrg (2.0) -Gilles Chanteau- 15/09/2007
;;; To change the start point of a closed polyline
(defun c:plineorg (/ erreur os pt pl plst norm nb n blst pa d1 d2 d3)
(vl-load-com)
(defun erreur (msg)
(if (= msg "Function cancelled")
(princ)
(princ (strcat "\nError: " msg))
(setvar "OSMODE" os)
(setq *error* m:err
m:err nil
(setq m:err *error*
*error* erreur
os (getvar "OSMODE")
(setvar "OSMODE" 515)
(if (and
(setq pt
(getpoint
"\nSelect a new start point on the polyline: "
(setq pl (car (nentselp pt)))
(setq pl (vlax-ename->vla-object pl))
(= (vla-get-ObjectName pl) "AcDbPolyline")
(= (vla-get-Closed pl) :vlax-true)
(progn
(vla-StartUndoMark (vla-get-ActiveDocument (vlax-get-acad-object)))
(setq plst (vlax-get pl 'Coordinates)
norm (vlax-get pl 'Normal)
pt (trans pt 1 0)
pa (vlax-curve-getParamAtPoint pl pt)
nb (/ (length plst) 2)
n nb
(repeat n
(setq blst (cons (vla-getBulge pl (setq n (1- n))) blst))
(if (= pa (fix pa))
(setq n (fix pa)
plst (append (sublist plst (* 2 n) nil)
(sublist plst 0 (* 2 n))
blst (append (sublist blst n nil) (sublist blst 0 n))
(setq n (1+ (fix pa))
d3 (vlax-curve-getDistAtParam pl n)
d2 (- d3 (vlax-curve-getDistAtPoint pl pt))
d3 (- d3 (vlax-curve-getDistAtParam pl (1- n)))
d1 (- d3 d2)
pt (trans pt 0 (vlax-get pl 'Normal))
plst (append (list (car pt) (cadr pt))
blst (append (list (k*bulge (nth (1- n) blst) (/ d2 d3)))
(sublist blst 0 (1- n))
(list (k*bulge (nth (1- n) blst) (/ d1 d3)))
(vlax-put pl 'coordinates plst)
(repeat (setq n (length blst))
(vla-setBulge pl (setq n (1- n)) (nth n blst))
(vla-EndUndoMark (vla-get-ActiveDocument (vlax-get-acad-object)))
(prompt "\nUnvalid entity.")
(princ)
;;; SUBLIST Return a sub-list
;;; Arguments
;;; lst : a list
;;; start : start index for the sub-list (first item = 0)
;;; leng : sub-list length (or nil)
;;; Examples :
;;; (sublist '(1 2 3 4 5 6) 2 2) -> (3 4)
;;; (sublist '(1 2 3 4 5 6) 2 nil) -> (3 4 5 6)
(defun sublist (lst start leng / n r)
(if (or (not leng) (< (- (length lst) start) leng))
(setq leng (- (length lst) start))
(setq n (+ start leng))
(repeat leng
(setq r (cons (nth (setq n (1- n)) lst) r))
;; K*BULGE
;; Returns a bulge which is proportional to a reference
;; Arguments :
;; b : the reference bulge
;; k : the ratio (between angles or arcs length)
(defun k*bulge (b k / a)
(setq a (atan b))
(/ (sin (* k a)) (cos (* k a)))
