entmod a dxfcode of a BlockLinearParameter
prountzos509
Message 1 of 11
prountzos509
Is there a way to modify a dxf code of a BlockLinearParameter
(setq lst ((-1 . <Entity name: 30f5358c0b0>) (0 . "BLOCKLINEARPARAMETER") (5 . "661D63") (102 . "{ACAD_XDICTIONARY") (360 . <Entity name: 30f5358c750>) (102 . "}") (330 . <Entity name: 30f5358c0a0>) (100 . "AcDbEvalExpr") (90 . 48) (98 . 33) (99 . 329) (100 . "AcDbBlockElement") (300 . "Linear") (98 . 33) (99 . 329) (1071 . 32) (100 . "AcDbBlockParameter") (280 . 1) (281 . 0) (100 . "AcDbBlock2PtParameter") (1010 0.0 0.0 0.0) (1011 0.240209 0.549818 0.0) (170 . 4) (91 . 52) (91 . 49) (91 . 0) (91 . 0) (171 . 1) (92 . 52) (301 . "DisplacementX") (172 . 1) (93 . 52) (302 . "DisplacementY") (173 . 1) (94 . 49) (303 . "DisplacementX") (174 . 1) (95 . 49) (304 . "DisplacementY") (177 . 0) (100 . "AcDbBlockLinearParameter") (305 . "Distance1") (306 . "") (140 . 0.076861) (307 . "") (96 . 8) (141 . 0.6) (142 . 1.0) (143 . 0.1) (175 . 0)))
i have reached to this lst
and i want to (entmod (subst (cons 96 7) (assoc 96 lst) lst)) but i get the error message :
; error: bad DXF group: (1071 . 32)
My knowledge roofed and i need some assistance
Replies (10)
Message 2 of 11
komondormrex
i think there is not. 1071 is a group code for the extended data supposed to be in -3 sublist, that is why you get the error.
Message 3 of 11
prountzos509
i posted the list which contains (1071 . 32) so its there for some reason
Message 4 of 11
komondormrex
yeah, it is there for some reason known to autocad developers, but getting any dxf does not necessarily mean that you just can entmod it. btw entmod
modifies the definition of an object (entity), whereas dynamic property ain't one. so the answer is still there is not.
Message 5 of 11
Moshe-A
@prountzos509  hi,
what is dxf96? what property do you want to change?
maybe try activex or (command) function.
Moshe
Message 6 of 11
prountzos509
dxf 96 controls the dist type and 7 is used for increment 3 for none and 8 for list
furthermore dxf 141 stores the dist increment 142 the dist minimum and 143 dist maximum
So when i insert a block i want to assign linear parameters with different values on all the above without the need of doing it after
Message 7 of 11
prountzos509
The general question is :
Is there any command or a way to change those values other than the properties window ?
Message 8 of 11
ВeekeeCZ
If you don't find any better way, set those values from block editor - open editor, change the setting, close.
something like...
(command "_.-bedit" "blockname")
(setpropertyvalue ename-of-parameter "PropertyName" value)
(command "_.bsave" "_.bclose")
Message 9 of 11
prountzos509
well initially i can (command "-bparameter" "l" "V" ...) for value set but the question still remains
i mean if you already have a block with linear parameter how you can modify its properties via coding
value of the linear parameter isits length and it can be modified with the setpropertyvalue function
Message 10 of 11
ВeekeeCZ
Post a block and screenshot of what exactly you want to change from what to what.
Edit: here's a quick test on attached block
(defun c:test ()
  (setq n (getint "new min: "))
  (command "_.-bedit" "rect")
  (and (setq l (ssget "X"))
       (setq l (vl-remove-if 'listp (mapcar 'cadr (ssnamex l))))
       (setq l (vl-remove-if-not '(lambda (e) (and (not (vl-catch-all-error-p (setq x (vl-catch-all-apply 'getpropertyvalue (list e "DistanceName")))))
						   (= x "Distance1")))
		 l))
       (vl-catch-all-apply 'setpropertyvalue (list (car l) "BlockParamValueSet/Minimum" n))
Message 11 of 11
prountzos509
This is exactly what i want.
Thanks a lot. Works also with everything else even with those i dont need atm.
dumpallproperties and problem solved
btw dxf codes are different in dumpallproperties  from what i get from dictsearch method.
I mean increment is 1 instead of 7 i wrote before, list is 2 instead of 8 and none is 0 instead of 3. Strange
Thanks so much ВeekeeCZ for the contribution and the interest.
Amazed with the altitude i have to climb.
