Is dynamic fillet rotation possible?
kuiva
kuiva
Hi I'm trying to make a block that is an L shape with a 4-value fillet in the corner of the two lines. Then I would want to rotate the top line so that the angle between the two lines could be anything. BUT at the same time I would like to retain the fillet between the lines? Is this possible?
MMcCall402
Here's one way to do it.  Use an Angle constraint between the two line segments and then auto-constrain the lines and curve together. Then add a radius constraint to hold the curve radius as it thru the different angles. (set its grip to 0)
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
Brock_Olly
I'm not that good with constraints so also wanted to give it a shot.
This is one without dimensional constraints, only geometric.
kuiva
Thanks! Both of these seem to work adequately 🙂 If I might ask a follow up question, would similar be possible for a sheet metal L profile block drawn with a "hollow inside". I tried to use similar constraints but didn't quite get there. Also if the length of the sides of the L were stretchable, it would be a bonus!
