Wish Vault API or Inventor API have access to vault revision table for ilogic workflows
I have a wish to be able to do the steps below within a ilogic script:
  1. On the Ribbon, select the Annotate tab and click the Table panel  -> Vault Revision command.
    Note: The mapped fields for a Vault Revision Table in a non-vaulted drawing display empty values to reflect the null state of information in the vault.
  2. Click on a position in the graphics window to place the Vault Revision Table.
currently a vba script is required with a mouseclick event which can cause trouble if the location of the mouseclick is not on window of inventor.
For example a RevisionTablesVault and/or RevisionTableVault object with similar functionality as the RevisionTable / RevisionTables object. But now referencing the Vault Revision Table
2 Comments
ihayesjr
@DavidWarta
Thank you for posting the Idea, what would your iLogic script do to the Vault Revision Table since the drawing is not in the Vault yet?
DavidWarta
Use case is updating old pre vault drawings without an vault revision table. The script replaces border, title block and removes the inventor revision table and adds the vault controlled revision table. Currently only a direct command will place the vault revision table with a mouse click event. I can't get it to be placed relative to the sheet edges.
I have another thread about this topic.
ilogic-rule-for-placing-the-vault-revision-table-on-a-inventor
