I have a wish to be able to do the steps below within a ilogic script:
- On the Ribbon, select the Annotate tab and click the Table panel -> Vault Revision command.
Note: The mapped fields for a Vault Revision Table in a non-vaulted drawing display empty values to reflect the null state of information in the vault.
- Click on a position in the graphics window to place the Vault Revision Table.
currently a vba script is required with a mouseclick event which can cause trouble if the location of the mouseclick is not on window of inventor.
For example a RevisionTablesVault and/or RevisionTableVault object with similar functionality as the RevisionTable / RevisionTables object. But now referencing the Vault Revision Table
