Vault library files automatic get behavior
On each Part in Vault there is an automatic get behavior if the file is in a newer version available.
This is not happening on a Library Configured part.
In our Company the customized Standard parts will be updated from time to time from the Material Master Response Person.
Means on all ASM where this modified Library Part is places must be updated, this is not happening automatically, user must trigger this with command GET
I wish there is a setting to configure the automatic get behavior of a library file in Vault. (Same open behavior as a normal Part in Vault)
2 Comments
johan.degreef
Also Content center parts.
ihayesjr
@stefan.hoeflinger
Have you tried using Workspace Sync to do this on Library folders?
