Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
ECO Custom Properties Sort Order
At current we can create Custom properties in Autodesk Vault for ECO but there is no provision to sort this properties as per the user requirements. By default the ECO form is  arranging the properties alphabetically which is a challenge. It would be good to have sort option may drag and drop or move the properties up and down. This would facilitate the user to have a ECO Form print as per there company format.
Appreciate if this is taken care so that the ECO form property creations makes sense
Regards
VinaySuresh
1 Comment
Hunteil
I know this is a pain and a crappy workaround. But you can always rename the UDP to have  1, 2, 3 in front of the UDP... I'm personally against this workaround b/c that same UPD could be used elsewhere and it dirties the system etc etc. But this is the workaround I've been told before when I asked for the same thing. šŸ˜ž
