Copy Design - Create multiple separate copies of the same source file in Vault
Develop a method to copy one source file, create multiple separated copies ao the same source file, at the same time.
2 Comments
ihayesjr
@filipa.rochaSD8RJ
Thank you for posting the idea. Can you elaborate why you are making so many copies of the same file?
bestek
I had the same issue several times in the past. A workaround is to re-select the file with RMB and use copy in the copy design dialog again.
