File automatic update
Hi, in the current version there is a problem after renaming the files: the problem is that after the rename command the actual version in the vault has the old part number and when is used for an article is keeping the old part number. The only way to fix this is to open the file and force a modification in order to create a new version with a "fresh" file that is also taking the new part number.
1 Comment
ihayesjr
@a.colomboWJ859
Thank you for posting the idea. The Rename wizard can update the part number and the rename operation. Are you using this option? What version of Vault are you using?
Can you provide steps that show the part number is not updating?
