Show only
Search instead for
No, I don't have any problems with those passwords, because primary those startup-icons are on the admins machine. Often we have the situation, that an admin password is widly shared with all other admins, if you have lots of them.
Regarding the password it could work as follows: If no password is given via a desktop-icon the user has to type in his password at least. But their is no need to select all the other things like server, three point for the correct database, retyping a different user and all of this. Especially for key-users, admins and all people, how have to logon to different vaults this might be a perfect help.
And by the way: With Autodesk Productstream Professional this was possible!!!!!!!
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can base on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
I have a requirement to switch between two separate Vault servers (on Vault Pro 2022 and higher) with different Authentication methods ("Windows Account" and "Autodesk ID"). I need a way to quickly toggle between them. Solution can be a drop-down in Vault Pro client, URL or startup command line switch for a shortcut. This would also allow other members of a team to do the same. Password is not needed.
This is nearly possible with the following call to ADMS to generate ACR file as a shortcut. But this method is still incomplete without an option to define the Authentication method
Alternatively, it might be helpful to provide an option in the XML shortcut file at the following location to switch between default auto login connection.
"%AppData%\Autodesk\Autodesk Vault Professional 2022\ApplicationPreferences.xml"
