What is the current status of Project Thunderdome, referenced here?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Vault-Option-Delet...
The link to the app was a dead end.
Solved by ihayesjr. Go to Solution.
That application is no longer developed.
@Ole_Dahl @ihayesjr
You can access the source code (provided without warranty) for 2024 version and earlier with the installer here: (Special thanks to @Markus.Koechl)
https://github.com/koechlm/Vault-Thunderdome-Sample
I attempted to migrate to the 2025 version, but encountered some errors after updating references. Hopefully, a 2025 version will be available soon.
My ideas, make admins' lives easier, please upvote!
Custom DXF Job Processor Settings for Inventor Flat Patterns
Event Handler for Detecting Raytracing Progress
Run Autodesk Uninstall Tool Remotely with Flags
@jzarczynski: Please carefully differentiate "Project Thunderdome" (retired with version 2020) from the "Vault Thunderdome Sample" code template, which was updated today to 2025. It is important to respect all restrictions listed on the release page and in the disclaimer!
