Custom .dxf Job processor settings for Inventor flat patterns
In the settings of the Job Processor for 2D Inventor files, it is currently possible to utilise a custom .ini file with settings exported from Inventor. However, it is not feasible to define these settings for Inventor flat patterns, nor is there any manual solution to this issue.
This problem has been raised by numerous users in the thread:
https://forums.autodesk.com/t5/vault-forum/new-2024-dxf-job-process-config-file-for-flat-pattern/td-...
Could the development team please look into this matter and consider implementing a feature that allows for such customisation? Many of us are keenly awaiting a resolution that would facilitate the handling of flat patterns more efficiently.
Kind Regards,
Jaromir
1 Comment
cassiano.godoy
Estou com o mesmo problema relatado neste post e no mencionado do link acima.
No Vault Professional 2024 tem a opção de selecionar um arquivo .ini com as configurações, mas mesmo exportando este arquivo do Inventor 2024, não funciona. O Vault continua exportando a forma padrão e esta não consigo utilizar.
Obrigado
