PDF Publish to a relative directory
rob.batog
rob.batog
I'm looking for a way to have Vault publish PDFs from IDWs relative to the source directory.
For example, if my idw was located in Drive/IDW, the PDF should be published in Drive/PDF.
I tried looking for a way via the Vault browser, and the job processor configs but so far, no luck.
Is there a documented way of doing this?
Thanks!
arkad_s
Autodesk Support
Autodesk Support
Out of the box you can configure it only to be in the same folder as source file or one specific folder set globally - https://help.autodesk.com/view/VAULT/2025/ENU/?guid=GUID-8EE12D8F-2381-4EE1-BAB0-D080F692500B
You might wish to vote/comment this idea - https://forums.autodesk.com/t5/vault-ideas/publish-to-folder-relative-to-source-file/idi-p/12416185
Arek
Arkadiusz Sukta
Technical Support Specialist
Customer Technical Success
rob.batog
Thanks for this @arkad_s
I replied in that thread. Hopefully it gets some traction.
Is there a way I can configure this on my own? Job Processor config perhaps?
Robert
arkad_s
Autodesk Support
Autodesk Support
Out of the box you can use only options described in  https://help.autodesk.com/view/VAULT/2025/ENU/?guid=GUID-8EE12D8F-2381-4EE1-BAB0-D080F692500B
Job Processor config file doesn't control location of published PDF files in Vault.
Arkadiusz Sukta
