Is it possible to filter original files from their shortcuts/links? For example i have one folder with many pdfs and some of them are linked to folders with projects. When I search through all folders i can see original pdfs and also many links/shortcuts. Is it possible to filter those shortcuts?
Similar issue:
https://forums.autodesk.com/t5/vault-ideas/filter-shortcuts-from-searches/idi-p/7504938
Solved by arkad_s. Go to Solution.
Does this help?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-exclude-lin...
It talks about searching but in normal view you can also enable Link Target Path column and filter it:
Arek
