Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Is it possible to filter shortcuts/links?
2 REPLIES 2
r_rybinskiA9RRF
161 Views, 2 Replies
Is it possible to filter original files from their shortcuts/links? For example i have one folder with many pdfs and some of them are linked to folders with projects. When I search through all folders i can see original pdfs and also many links/shortcuts. Is it possible to filter those shortcuts?
Similar issue:
https://forums.autodesk.com/t5/vault-ideas/filter-shortcuts-from-searches/idi-p/7504938
2 REPLIES 2
arkad_s
in reply to: r_rybinskiA9RRF
Does this help?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-exclude-lin...
It talks about searching but in normal view you can also enable Link Target Path column and filter it:
Arek
Arkadiusz Sukta
Technical Support Specialist
Customer Technical Success
This is it! Thank you.
