Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Error 244 When trying to map PDF thumbnails
6 REPLIES 6
rob.batog
370 Views, 6 Replies
We're trying to map PDF thumbnails so that they display correctly in our Vault. It's not a new Vault so we have to map it manually.
We're getting the following error:
I tried looking at the support articles, but there were none for this specific problem. What could be the reason for this?
Robert
6 REPLIES 6
ihayesjr
in reply to: rob.batog
@rob.batog
What version of Vault are you using?
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
rob.batog
in reply to: ihayesjr
@ihayesjr
We are currently on Vault 2024.2 Update for both client and server.
ihayesjr
Please check your server logs to see if they provide more information about this error.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
R_M_Olsson
For a work around, remove all thumbnail-mappings for Revit, then it will work.
R_M_Olsson
For a work around remove all Revit thumbnail mappings, then it will work for PDF.
Kent_Norling
Hi!
If you remove all Revit mappings to the Thumbnail property it will work.
My guess is if  you don´t have Revit installed the default Revit thumbnail mappings is the problem.
// Kent
