Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Dwf Visualisation multi sheet drawing problem from Inventor 2023 to vault pro
1 REPLY 1
mikejones
199 Views, 1 Reply
when checking Inventor dwg files into Vault pro 2023 we're having an issue with drawings that have more than 1 drawing sheet. Basically the dwf visualisation file that is created is only the last sheet in the drawing. Any idea or reason why this would be the case.
Mike
Autodesk Certified Professional
1 REPLY 1
bonnrhee
in reply to: mikejones
In the visualization options is the "All sheets" option checked?
On the VIEW tab, did you check the "Document Browser"?
See attachments
