Dwf Visualisation multi sheet drawing problem from Inventor 2023 to vault pro
mikejones
mikejones
when checking Inventor dwg files into Vault pro 2023 we're having an issue with drawings that have more than 1 drawing sheet. Basically the dwf visualisation file that is created is only the last sheet in the drawing. Any idea or reason why this would be the case.
Mike
Autodesk Certified Professional
bonnrhee
In the visualization options is the "All sheets" option checked?
On the VIEW tab, did you check the "Document Browser"?
See attachments
