Check-in Error 0 - Unknown Server Error
tobias
Message 1 of 8
tobias
I have updated Vault 2022 to 2023 including 2023.0.1. The installation went smooth and everything worked fine untill check-in files. From Vault I have following error message:
check-in from Inventor:
Server Logbook:
Any ideas ? Thanks
Tobias
The Netherlands
Inventor Pro 2026, Vault Pro 2026, AutoCad Electrical 2026.
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Replies (7)
Message 2 of 8
gandhey
Can you please check if following helps :
https://knowledge.autodesk.com/support/autocad-mep/troubleshooting/caas/sfdcarticles/sfdcarticles/Er...
Yogeshwar
(Vault team)
Message 3 of 8
tobias
@gandhey ,
Thanks, yes I tried it and made no difference.
What concerns me is what is mentioned in the server log:
Exception(Inner): There is already an Item with de same key added.
 (Translated from Dutch)
It looks like there something double, but what ?
Tobias
The Netherlands
Message 4 of 8
Gabriel_Watson
It seems to me that something is getting lost in your property mapping sync, according to the logs there. That would align with a similar thread below, which may help solve this:
https://forums.autodesk.com/t5/vault-forum/error-quot-an-item-with-the-same-key-has-already-been-add...
You may have to open up a support ticket and show them your Vault property mapping and test without it enabled to confirm that is the issue.
Message 5 of 8
tobias
Thanks, I opened a support case. To be continued...
Tobias
The Netherlands
Message 6 of 8
tobias
Autodesk Support solved my problem. If I understood correctly they found a dll file with a wrong entry.
This is configuration dependent.
Tobias
The Netherlands
Message 7 of 8
tobias
Autodesk Support find the double entry as follow:
Tools > Administration > Vault Settings > Behaviors > Properties
My part number had 2 mappings. I deleted the custom entries.
Tobias
The Netherlands
Message 8 of 8
jimmy.wick90
Try to get the support assistance... you can also try to check for the updates of the autodesk or else if nothing is working just raise assistance.
Jimmy
