Hi alavath,
Does the issue go away if you restart Softimage?
Is your undo level set to a number higher than 0?
Best regards.
Francis
Hi @Anonymous,
If you could find out the exact repro steps that leads to break the undo, I might be able to find you a workaround.
Best regards,
Francis
I had to lower my undo level. I had it up to 75 and then started getting the random "undo disabled" problem. I lowered it down to 15, restarted XSI, and it seems to be working now. Maybe having a high undo level is taking up too many resources and XSI freaks out and just disables it altogether?
Cory Wright
I also noticed that if I made one change, then saved, it would let me undo, even the one change I made before saving.
Ive been having an issue with undo -
In preferences - my settings for undo are either on infinite or 1000 but always turned on -
In the beginning of my scene its working fine, and after a certain point, usually around the 10th key (animation ) the undo key stops working - I've tried updating, using different versions, but it is happening across all my versions and updates will not stop in - I've also tried uninstalling and installing again
Any ideas?
