Softimage Forum (Read Only)
Welcome to Autodesk’s Softimage Forums. Share your knowledge, ask questions, and explore popular Softimage topics.
Undo not working??
13 REPLIES 13
Message 1 of 14
30054 Views, 13 Replies
Undo not working??
Hi, I've got a slight problem. It seems my undo's aren't working 😕
They are greyed out in the edit menu. Whenever I'm modeling and I want to go back a step I can't undo.
I'm NOT modeling in the immediate mode, so that can't be the problem.
Anybody had this before and know how to solve this?
Thanks. Simon
13 REPLIES 13
Message 2 of 14
Go to File>Preferences>General and check to see how many "undos" you have, it might have mysteriously changed to zero, if so then just increase the #.
Message 3 of 14
Thanks AceMastermind, that was the solution!
Seems there is some ghost inside XSI couse it sometimes also turns off the property panels you get when creating new geometry (but I know how to set them on again). 😄
Message 4 of 14
Happened to me a little while ago to. Strange isn't it.
Message 5 of 14
Hi Ethangar, good to see you here 😄
But you are right, it is quite particular that XSI seems to change it settings on its own. Maybe its the advanced character-animation-AI ??
Message 6 of 14
I got both.. No property pages and the undo thing. I in immediate mode a few times before so I just figured that had something to do with it.
Message 7 of 14
So I tried this but the undo/redo still does not work so what is the fix?
Message 8 of 14
brissef2
Hi alavath,
Does the issue go away if you restart Softimage?
Is your undo level set to a number higher than 0?
Best regards.
Francis
Message 9 of 14
Hi, not working for me either. Settings are at 50. It works for a bit and then conks out. Update didn't fix it. Operating from a Mac book air. Annoying!
Message 10 of 14
brissef2
Hi @Anonymous,
If you could find out the exact repro steps that leads to break the undo, I might be able to find you a workaround.
Best regards,
Francis
Message 11 of 14
in reply to: brissef2
I had to lower my undo level. I had it up to 75 and then started getting the random "undo disabled" problem. I lowered it down to 15, restarted XSI, and it seems to be working now. Maybe having a high undo level is taking up too many resources and XSI freaks out and just disables it altogether?
Cory Wright
Message 12 of 14
If it takes up too much resources, the XSI will crash and disable it quickly, this is no doubt ,
Message 13 of 14
I also noticed that if I made one change, then saved, it would let me undo, even the one change I made before saving.
Message 14 of 14
npchurchill
Ive been having an issue with undo -
In preferences - my settings for undo are either on infinite or 1000 but always turned on -
In the beginning of my scene its working fine, and after a certain point, usually around the 10th key (animation ) the undo key stops working - I've tried updating, using different versions, but it is happening across all my versions and updates will not stop in - I've also tried uninstalling and installing again
Any ideas?
